Latex output problems
XcasEngGuy
Message par XcasEngGuy » mer. sept. 11, 2013 5:19 pm
I noticed you included a "dot" between variables that are multiplied together in the latex output. This helps a problem I have been having. However, the "dot" only seems to be included between the first two variables encountered in a given equation.
Here is an example
I hope that worked.
Could you fix it so all products are identified with a "dot" to eliminate confusion in variable names? Or make it an option? For example, "m*a*s*s" would look like "mass" right now. I am using xcas 1.0.0-4 (c) 2000-8.
Thanks,
Matt
Re: Latex output problems
Message par parisse » jeu. sept. 12, 2013 6:49 am
Try the latest version of xcas (1.1.0-10), it seems to be ok.
