Xcas-online version
Xcas-online version
Message par compsystems » mer. sept. 27, 2017 10:55 am
Hello, the example
http://www-fourier.ujf-grenoble.fr/%7ep ... t%2Cplot)&
1: how can i export it to xcas-pc format?
2: and from xcas-pc how can I export it so that it can be run in the Xcas-online version
3: as a suggestion add a title, such as Xcas-online or web-Xcas
4: please include insert new entry line in the web version
Re: Xcas-online version
Message par parisse » mer. sept. 27, 2017 1:00 pm
compsystems a écrit :Hello, the example
Right-click on clone, then in Xcas select a level and press Ctrl-V
File menu > Clone
This will only support normal CAS sessions (no spreadsheet, no geometry0
I won't. You can easily move levels around with the arrow buttons.
Message par compsystems » mer. sept. 27, 2017 3:36 pm
I can not pass a session from the window to web version
4: the trick is to click on the empty entry line to insert a new line at the end of the history and then move n lines, but if there are too many lines this is too laborious, it is very important to insert new lines in a session that shows commands sequential
Message par parisse » mer. sept. 27, 2017 5:04 pm
It works with the French webpage xcasfr.html, it should not open the English one if your xcas version is up to date.
If you are not happy with the current insertion mechanism, you can modify xcasfr.html, it's javascript code.
Message par compsystems » mer. sept. 27, 2017 6:38 pm
:cry:
