Hello, the example
http://www-fourier.ujf-grenoble.fr/%7ep ... t%2Cplot)&
1: how can i export it to xcas-pc format?
2: and from xcas-pc how can I export it so that it can be run in the Xcas-online version
3: as a suggestion add a title, such as Xcas-online or web-Xcas
4: please include insert new entry line in the web version
Xcas-online version
Re: Xcas-online version
Right-click on clone, then in Xcas select a level and press Ctrl-Vcompsystems a écrit :Hello, the example
File menu > Clone2: and from xcas-pc how can I export it so that it can be run in the Xcas-online version
This will only support normal CAS sessions (no spreadsheet, no geometry0
I won't. You can easily move levels around with the arrow buttons.4: please include insert new entry line in the web version
I can not pass a session from the window to web version
4: the trick is to click on the empty entry line to insert a new line at the end of the history and then move n lines, but if there are too many lines this is too laborious, it is very important to insert new lines in a session that shows commands sequential
It works with the French webpage xcasfr.html, it should not open the English one if your xcas version is up to date.
If you are not happy with the current insertion mechanism, you can modify xcasfr.html, it's javascript code.
