Latex possible bug?
XcasEngGuy
Latex possible bug?
It appears that xcas is no longer putting in the parenthesis around the argument in sin:
The xcas entry: produces: \(\left[\begin{array}{c}a=\mathrm{str2}\cdot \sin \mathrm{ang}\\b=\mathrm{str2}\cdot \cos \mathrm{ang}\end{array}\right]
% Generated by xcas
\documentclass{article}
\usepackage{pst-plot,color}
\usepackage{graphicx}
\begin{document}
\noindent \framebox{1} {\tt eq1:=[[a=(str2*sin(ang))],] } \\
\begin{equation} \label{eq:0}
\end{equation}
\noindent \framebox{2} {\tt } \\
\end{document}
% Generated by xcas
\begin{document}
\end{equation}
\end{document}
- Pièces jointes
- Clipboard01.jpg (6.1 Kio) Consulté 13335 fois
- Clipboard01.jpg (6.1 Kio) Consulté 13336 fois
XcasEngGuy
Re: Latex possible bug?
My post got corrupted somehow, hope you can understand it. I was not able to edit it.
Matt
Matt
It seems it is a question for Luka.
Note that you can run
in your session before converting to latex, this should switch to my old latex code with parenthesis around the argument.
latex("legacy",1)-
XcasEngGuy
Thanks. That helps but it breaks some of my recent tweaks using perl scripts to change diff(x(t),t,2), for example, to a more textboox style:
\(\frac{d2\left(\text{y(t)}\right)}{\mathrm{dt2}}=\frac{4 \sqrt{10} \frac{d2\left(x(t)\right)}{\mathrm{dt2}} \sqrt{x\left(t\right)}^{-1}}{2}-4 \sqrt{10} \frac{1}{2} \frac{d\left(\text{x(t)}\right)}{\mathrm{dt}} \frac{1}{2} \frac{d\left(\text{x(t)}\right)}{\mathrm{dt}} \sqrt{x\left(t\right)}^{-1} x\left(t\right)^{-1}
XcasEngGuy
Even better (added tweak):
\(\frac{d^{2}\left(\text{y(t)}\right)}{\mathrm{dt^{2}}}=4 \sqrt{10} \frac{d^{2}\left(x(t)\right)}{\mathrm{dt^{2}}} \frac{\sqrt{x\left(t\right)}^{-1}}{2}-4 \sqrt{10} \frac{1}{2} \frac{d^{}\left(\text{x(t)}\right)}{\mathrm{dt^{}}} \frac{1}{2} \frac{d^{}\left(\text{x(t)}\right)}{\mathrm{dt^{}}} \sqrt{x\left(t\right)}^{-1} x\left(t\right)^{-1}\)
New latex conversion omits parentheses when applying functions to simple arguments like e.g. x. I will add an additional condition that the argument must be a one-letter symbol, which should make the output better (one-letter symbols are typeset in italic, so removing parentheses wouldn't affect readability).
XcasEngGuy
Sounds good, Thanks
