Function variables declared as global! Why?
Publié : sam. mars 31, 2012 2:16 pm
				I discovered this trying to write a function that processes each element of a matrix.
It seems that if there is any level of complexity in the function, the arguments are treated as globals!
I am not sure, but I think this may even be related to the problem of currying which I mentioned in the giac forum.
In any case I would welcome opinions.
Suppose I have a matrix and I want to generate another matrix, where every element is, say, the sin() of the original.
I thought I would use makemat/3 taking advantage of its built-in properties, rather than loop through the whole matrix.
Here's on version of it, it tried some other versions too, but they all behave about the same.
This compiles, but with the following warnings!
Any ideas?
I also want to add that this way of writing the function is very inefficient, the following code taking just over 1 second for a 100x100 matrix, 15 seconds for a 200x200, 80 seconds for a 300x300, 260 for a 400x400 and 592 for a 500x500!
That would suggest a time of O(n^4) instead of O(n^2).
Ouch! So much for using the builtin...
Thanks
mat_func(m_1,f_1):= {
local j,k,
matfunc1 := (j,k) -> (f_1(m_1[j][k]));
makemat(matfunc1,nrows(m_1),ncols(m_1));
// Warning: f_1,m_1, declared as global variable(s)
// Parsing mat_func
// Success compiling mat_func
(m_1,f_1)->
{ local j,k,(matfunc1:= (j,k)->f_1((m_1[j])[k]));
m1:=randmatrix( 500,500,'randnorm(0,1)');
n11:=mat_func(m1,sin);
