Hello, some small problems
1: [Save] field overlaps
2: The name of the second graphic does not appear.
3: frame work, the flag seems to be inverted
4: ticks must have at least one space, because it gives the appearance of negative numbers -80 -> - 80
also place a space before the units
gl_x_axis_unit="x_u", gl_y_axis_unit="y_u";
0y_u -> 0 y_u
I think the units label should only go on the axes
ideas:
A: the menu M, label it completely M -> Menu or Mn, and cursor labels
B: I think that the outputs that repeat the input, ie they are identical, better return DONE
title="titlename",labels=["x_name","y_name"]; ->
title="titlename", labels=["x_name","y_name"]; ->
(Done, Done)
Question on Global attributes:
https://www-fourier.ujf-grenoble.fr/~pa ... de546.html
I: the gl_showplotnames Global attributes is defined as cmd?
gl_showplotnames=true
II: gl_texture="filename": background image
places a background image from a path?
texture="E:\2017\MSc\SMC\Xcas\graphing\buran.png"; do not work
some small problems on graphic and simples ideas
