Inputs cmds
Inputs cmds
Message par compsystems » jeu. févr. 01, 2018 4:16 am
Hello, BP
The variable "d" is stored correctly using InputStr. Is possible that inputForm specifies the type of object to receive?
Thanks
test_inputs():={
	local a;
	local b;
	local c;
	local d;
	print();
	input( "integer", a );
	input( "real", b );
	input( "boolean", c );
	InputStr( "string", d );
	print( a );
	print( b );
	print( c );
	print( d );
	inputform( "integer", a, "real", b, "boolean", c, "string",d  );
	print( a+" "+b+" "+c+" "+d );
inputForm does not decode the variable d
Re: Inputs cmds
Message par parisse » jeu. févr. 01, 2018 12:43 pm
I don't see what's wrong. Inside the inputform you must of course surround the string d with ", because otherwise it is parsed (and this will error if the field is not a valid commandline).
Re: Inputs cmds
Message par compsystems » jeu. févr. 01, 2018 12:51 pm
ok, but to avoid writing the quotes, (idea) you can add an optional extra parameter that determines the type of object
inputform( "integer", a, "real", b, "boolean", c, "string", [ d DOM_STRING ] );
Re: Inputs cmds
Message par parisse » jeu. févr. 01, 2018 1:03 pm
I don't want to do things like that, because I think that interactive inputs should be avoided as soon as possible, one should teach functions and arguments as soon as possible instead.
