Recognition of assume(s,DOM_STRING);
Message par compsystems » ven. sept. 07, 2018 10:34 pm
Hello, although there is the InputStr command to capture a string type data, for example with spaces, I think that the INPUT command could also act similarly if the variable is predefined as a string
EXAMPLE 1
InputStr("Enter a string",s);
print("s="+s);
If the user enters 1 2 3
print
1 2 3 // ok
EXAMPLE 2
input("Enter a string",s);
print("s="+s);
syntax error // ok
EXAMPLE 3
print("s="+s);
should not return syntax error, because the expected type is a string
Re: Recognition of assume(s,DOM_STRING);
Message par parisse » sam. sept. 08, 2018 5:58 am
input does not check anything on the previous content of variables, it just overwrites. Like := or assume. And I don't see why it would be better to run 2 commands (assume+input) instead of 1 (InputStr).
