Conver PSEINT a XCAS
Message par compsystems » dim. sept. 16, 2018 1:06 am
Hi BP, PSEINT is a software to learn programming logic that can also export to different languages c/c++, I have collaborated with the translation to XCAS, see below, the conversion works well, wait for next news.
Just as a suggestion, we want the word Done to be reserved, so that the compilation does not throw the global variable message
thank you very much.
PSEINT HOME PAGE
http://pseint.sourceforge.net/slide/pseint.html
sin_titulo_00():={
	DispG; ClrIO; ClrGraph;
	printf( "Hola Mundo" );
	Pause; DispHome;
	return Done;
sin_titulo_01():={
	local a, b, c, d, ee_, f, p;
	assume(a,integer)
	assume(b,real);
	assume(c,integer);
	assume(d,integer);
	assume(ee_,DOM_STRING);
	assume(f,DOM_STRING);
	assume(p,DOM_STRING);
	a:=1;
	b:=2.5;
	c:=true;
	d:=false;
	ee_:="Hola";
	f:="Hola Mundo";
	InputStr("p",p);
	printf( p );
	Pause; DispHome;
	return Done;
sin_titulo_02():={
	local a;
	local b;
	local c;
	local d;
	assume(a,integer);
	assume(b,real);
	assume(c,DOM_STRING);
	assume(d,integer);
	input( "a", a );
	input( "b", b );
	InputStr( "c", c );
	input( "d", d );
	printf( a );
	printf( b );
	printf( c );
	printf( d );
	inputform( "a", a, "b", b, "c", c, "d",d );
	printf( string(a)+string(b)+ c +string(d) );
	printf( "Esta linea no lleva enter al final" );
	Pause; DispHome;
	return Done;
sin_titulo_03():={
	local c;
	assume(c,integer);
	c:=0;
	while c<=10 do
		c:=c+1;
	printf( c );
	end;
	c:=0;
	repeat
		c:=c+1;
		printf( c );
	until c=10;
	if c=10 then
		printf("Si");
	end;
	if c=10 then
		printf("Si");
	else
		printf("No");
	end;
	Pause; DispHome;
	return Done;
sin_titulo_04():={
	local a, b, c, d, ee_, n;
	assume(a,DOM_LIST);
	assume(b,DOM_LIST); assume(c,DOM_LIST); assume(d,DOM_LIST);
	assume(ee_,DOM_LIST);
	assume(n,integer);
	index:=1;
	a:= makelist( 10 );
	b:= matrix( 20, 30 );
	c:= makelist( 40 );
	d:= matrix( 50, 5 );
	Input("n",n);
	ee_:= makelist( n );
	Input( "a(1)", a[[1]] );
	a[[10]]:= a[[1]];
	printf( b[[10,10]] );
	Pause; DispHome;
	return Done;
sin_titulo_05():={
	local a, b, c, index_rows, index_cols, ii_, j;
	assume(a,DOM_LIST);
	assume(b,DOM_LIST);
	assume(c,integer);
	assume(index_rows,integer); assume(index_cols,integer);
	assume(ii_,integer); assume(j,integer);
	index:=1;
	a:= makelist( 10 );
	b:= matrix( 3, 6 );
	for ii_ from 1 to 10 do
		a[[ii_]] := ii_*10;
	end;
	for index_cols from 1 to dim(a) do
		printf( a[[index_cols]] );
	end;
	c:= 0;
	for index_rows from 1 to dim(b)[[1]] do
		for index_cols from 1 to dim(b)[[2]] do
			c:=c+1;
			b[[index_rows,index_cols]] := c;
		end;
	end;
	for ii_ from 3 to 1 step -1 do
		for j from 1 to 5 step 2 do
			printf( b[[ii_,j]] );
		end;
	end;
	return Done;
sin_titulo_06():={
	local c;
	assume(c,integer);
	input("c",c);
	switch(c){
		case 1:{
			printf("1");
			break;
		case 3:{
			printf("3, 5 o 9");
			break;
		case 5:{
			printf("3,5 o 9");
			break;
		case 9:{
			printf("3, 5 o9");
			break;
		case 7:{
			printf("7");
			break;
		default:{
			printf("no es 1, 3, 5, 7, 9");
			break;
	Pause; DispHome;
	return Done;
sin_titulo_07():={
	local a, b, c;
	assume(a,DOM_LIST);
	assume(b,DOM_LIST);
	assume(c,integer);
	a:= makelist( 10 );
	b:= matrix( 3, 4 );
	printf( FuncionDoble(5) );
	NoRetornaNada(3,9);
	c:=0;
	c:=PorReferencia(c);
	printf(c);
	RecibeVector(a);
	RecibeMatriz(b);
	return Done;
FuncionDoble(b):={
	local a; assume(a,integer);
	a:=2*b;
	return a;
NoRetornaNada(a,b):={
	printf("NoRetornaNada 9+3=");
	printf(a+b);
PorReferencia(b):={
	local b; assume(b,integer);
	b := 7
		return b;
RecibeVector(v):={
	input( "v(1)", v[[1]] );
	printf("v[[1]]=");
	printf( v[[1]] );
	v[[2]]:=50;
	printf("v[[1]]=");
	printf( v[[2]] );
RecibeMatriz(m):={
	input( m[[1,1]] );
	printf( m[[1,1]] );
	m[[1,2]]:=25;
	printf( m[[1,2]] );
sin_titulo_08():={
	local a,b,c,d,ee,f;
	assume(a,integer); assume(b,integer);
	assume(c,integer); assume(d,integer);
	assume(ee,DOM_STRING); assume(f,DOM_STRING);
	a:=11;
	b:=2;
	c:=true;
	d:=false;
	ee:="Hola";
	f:="Mundo";
	printf( "algebraicos");
	printf( a+b );
	printf( a*b );
	printf( a/b );
	printf( a-b );
	printf( a^b );
	printf( a mod b );
	printf( "relacionales");
	printf( a==b );
	printf( a?b);
	printf( a<b );
	printf( a>b );
	printf( a=b );
	printf( a=b );
	printf( "logicos");
	printf( c and d );
	printf( c or d );
	printf( NOT (c and d) );
	printf( "para cadenas" );
	printf( ee+" "+f ) ;
	printf( ee==f );
	printf( ee?f );
	printf( ee<f );
	printf( ee>f );
	printf( ee=f );
	printf( ee=f );
	Pause; DispHome;
	return Done;
sin_titulo_09():={
	local x,s;
	assume(x,real);
	assume(s,DOM_STRING);
	angle_radian:=1;
	x:=1.5;
	s:="Hola";
	printf( sqrt(x) );
	printf( abs(x) );
	printf( ln(x) );
	printf( exp(x) );
	printf( sin(x) );
	printf( cos(x) );
	printf( tan(x) );
	printf( asin(x) );
	printf( acos(x) );
	printf( atan(x) );
	printf( round(x) );
	printf( iPart(x) );
	printf( randint( 0, 15 ) );
	printf( size(s) );
	printf( Minusculas(s));
	printf( Mayusculas(s) );
	printf( mid(s,0,2) );
	printf( append(s," Mundo") );
	printf( append("Mundo ",s) );
	printf( expr("15.5" ) );
	printf( string(15.5) );
	Pause; DispHome;
	return Done;
Mayusculas(str):={
	local c, sout:="";
	local s:=size(str);
	local s2:="";
	for c from 0 to s-1 do
		s2:= mid(str,c,1);
	if (s2 >= "a" and s2 <= "z") then
		sout:= sout+ char( (65+ ord( s2 )-97 ));
	else
		sout:= sout+s2;
	end;
	end;
	return( sout );
Minusculas(str):={
	local c, sout:="";
	local s:=size(str);
	local s2:="";
		s2:= mid(str,c,1);
	if (s2 >= "A" and s2 <= "Z") then
		sout:= sout+ char( 97-(65-ord( s2 )) );
	else
		sout:= sout+s2;
	end;
	end;
	return( sout );
sin_titulo_10():={
	ClrIO; ClrGraph;
	Pause;
	WAIT( 1 );
	printf(p);
	Pause; DispHome;
	return Done;
Re: Conver PSEINT a XCAS
Message par parisse » dim. sept. 16, 2018 6:07 am
You can replace return Done; with return "Done";
