Converting a float polynomial to integer polynomial
jocaps
Message par jocaps » mer. sept. 19, 2018 7:56 am
Hi,
After some computations with algebraic numbers (as floats with high precision) I obtain a polynomial whose coefficients I know are integer but because the computations are done with floats, giac/xcas will show the coefficients with the decimals. I want to know what is the best way to convert this polynomial into an integral polynomial. As example:
I have the following polynomial:
0.30900000000000000000000000000000e3*x^6+0.11700000000000000000000000000000e4*x^5*y+0.47999999999999999999999999999999e2*x*y^2*z^3
This is a polynomial with integer coefficients. So from that I want to get
309*x^6+1170*x^5*y+48*x*y^2*z^3
any easy way of doing this in Xcas/giac?
Jose
lukamar
Re: Converting a float polynomial to integer polynomial
Message par lukamar » mer. sept. 19, 2018 8:06 am
Hello Jose,
I think the simplest way is to use the "exact" command:
p:=0.30900000000000000000000000000000e3*x^6+0.11700000000000000000000000000000e4*x^5*y+0.47999999999999999999999999999999e2*x*y^2*z^3;
exact(p)
The sensitivity depends on the epsilon constant which can be changed in session settings.
Luka
jocaps
Message par jocaps » mer. sept. 19, 2018 8:50 am
Hi Luka,
Wonderful, thanks a lot!
Apologies, I should have thought of that, I missed this command in the manual.
Jose
