cas_setup() cmd
Publié : dim. sept. 23, 2018 2:01 am
Hello, BP, please can include as argument number 13, autosimplify mode, with the purpose of full controlling in a single instruction.
Please also check the following documentation.
Thanks
cas_setup(arguments) Is the command for initialized the cas,
arguments:
1: Approximate mode, // int 1/0, exact (dft) or approx mode.
2: Complex var, // int 1/0, variables are complex or real (dft).
3: Complex, // int 1/0, complex mode (dft 0).
4: Angle, // int 1/0, Randian (dft) or Degree angle mode.
5: Float format //
Standard: 160 (dft)
Scientific: 161
Engineer: 162
6: [Epsilon, probability]// [Real, Real],
6.1: Epsilon, Number with absolute value less than epsilon can be coerced to 0
6.2 maximal probability of a wrong answer for non-deterministic algorithms. Set to 0 for deterministic algorithms only.
7: Digitis, // int, Digits (12 dft)
8: [Threads/Eval/Prog/recurs] //[Int, Int, Int] //
8.1 Threads // Maximal number of threads in parallel
8.2 Recurs: Number of embedded function calls allowed (100 dft)
8.3 Prog: Number of embedded variable names replacement in program evaluation (1 or 0 for default eval level)
8.4 Eval: Number of embedded variable names replacement in interactive evaluation (25 dft)
9: increasing power flag // int 1/0, Show polynomials In increasin or decreasing order (0 dft)
10: Sqrt // int 1/0, Factor 2nd order poly using sqrt (1 dft)
11: All trig sol. // int 1/0, Solver: principal solution vs all solutions (0 dft)
12:
Thanks
arguments:
5: Float format //
Standard: 160 (dft)
Scientific: 161
Engineer: 162
12:
