INTEGER() function command
Message par compsystems » jeu. nov. 29, 2018 2:11 pm
Hello BP, to give similarity to the Python syntax, please overload the INTEGER command
integer() as a function synonym of expr() and iPart() cmd
example
integer("42") [enter] 42
integer("1.25") [enter] 1
I note that the float command does operate in this way =)
float("3.14") [enter] 3.14
float(10) [enter] 10.0
Re: INTEGER() function command
Message par parisse » jeu. nov. 29, 2018 2:45 pm
integer does not exist in Python, it's int, and it's already in Xcas if you select Python syntax compatibility.
Message par compsystems » jeu. nov. 29, 2018 4:15 pm
Ok, but that the integer() command is available in xcas is also a good idea.
In addition, in some cases it is required to extract only the entire part of a number that is enclosed as a string.
About expr() cmd in the case of expr(5) return 5 and not expr(5)
Message par parisse » jeu. nov. 29, 2018 5:30 pm
int does that in Python mode. Please check before asking.
