WHILE block syntax
WHILE block syntax
Message par compsystems » sam. févr. 09, 2019 3:29 pm
Hello, the WHILE block syntax is as follows.
function while_example_()
begin
	local n;
	assume( n, integer );
	DispG; ClrIO; ClrGraph;
	n:=1;
	while (n <= 5)
        do
		printf( string(n) );
		n := n + 1;
	end
	return Done;
end;
function while_example_1()
begin
	local n;
	n:=1;
	while (n <= 5)
	begin
		n := n + 1;
	end
	return Done;
end;
function while_example_2()
	local n;
	n:=1;
	while (n <= 5)
		n := n + 1;
	return Done;
function while_example_3()
begin
	local n;
	n:=1;
	while (n <= 5)
	begin
		n := n + 1;
	end_while
	return Done;
end;
But these two combinations do not work
function while_example_4()
begin
	local n;
	n:=1;
	while (n <= 5)
        do
		n := n + 1;
	end_while
	return Done;
end;
function while_example_5()
begin
	local n;
	n:=1;
	while (n <= 5)
		n := n + 1;
	end_while
	return Done;
end;
Re: WHILE block syntax
Message par parisse » dim. févr. 10, 2019 2:11 pm
If you put a parenthesis after the while keyword, you select C-like syntax (while(){...}).
Message par compsystems » mar. févr. 26, 2019 2:44 pm
suppressing parentheses, does not recognize end_while
function while_example( )
begin
	local n;
	DispG; ClrIO;
	n := 1;
	while  n <= 5  do
		printf( n );
		n := n + 1;
	end_while
	return "Done";
end
Message par parisse » jeu. févr. 28, 2019 2:25 pm
Indeed. I will fix that. In the meantime, just replace by end.
