print(id,'off');
print(id,'off');
Message par compsystems » sam. févr. 09, 2019 4:11 pm
Hello PRINT command if the entry is an identifier, label the output with the name identifier, this is important, but sometimes you only want the value without a label, for this reason it is a good idea to add a second interpretation parameter where it is indicated that the label is not desired
any ideas
print(Area,'off');
print(Area,0);
print(Area,false);
function area_of_circle( )
begin
	local Area, Radious;
	ClrIO;
	printf( "Please enter the radius of a circle" );
	input( Radious );
	Area := 3.14 * Radious^2;
	print( "The area is " + Area );
        print(Area);
        print(Area,'off');
	return Done;
end
Re: print(id,'off');
Message par parisse » dim. févr. 10, 2019 2:13 pm
print(eval(identifier)) will not display the identifier name.
