* The constructor with brackets of polynomialis is poly1[ordered sequence (descending -> x) of elements]
poly1[-1,6,-11,6] > poly1[-1,6,-11,6]
* The functional constructor of sets is: set(unordered sequence of elements)
set(5,4,1, 1) > set[5,4,1]
* The constructor with set brackets is: set [unordered sequence of elements]
set[5,4,1, 1] > set[5,4,1]
* The functional constructor of tables is table(elements)
tbl1 := table( (0,0)=9,(1,1)=6)
To give uniformity to the Xcas syntax logic, the table constructor is also needed as table[]
tbl2 := table[ (0,0)=9,(1,1)=6 ]
table[] as constructor data
- Contact :
