copy and time cmd
Publié : lun. janv. 13, 2020 3:13 pm
Hi BP, Good morning
Porting the code to HP-prime, I observe that the time that Xcas throws does not approximate to deltalist(time(fract(320,240,10)))
Also the copy function res2:=copy(res1) in what differs of res2:=res1?
deltalist(time(fract1(320,240,10)))
// hpprime: input mode, linear (algebraic)
function fract(X_,Y_,Nmax) // Mandelbrot fractal, not using symmetry.
local x,y,z,c,j,w,h,res1,res2;
//freeze;
w:=2.7/X_;
h:=-1.87/Y_;
res1:=[];
Y_:=Y_-1;
for y from 0 to Y_ do
c:=-2.1+i*(h*y+0.935);
for x from 0 to X_-1 do
z:=0;
for j from 0 to Nmax-1 do
if abs(z:=z^2+c)>2 then break; fi;
od;
res1.append(pixon(x,y,126*j+2079)); // hpprime: res1.append(pixon_p(x,y,126*j+2079));
c:=c+w;
od;
od;
return res1; // hpprime: comment on this line, 10 thousand elements maximum
ffunction
:;Code : Tout sélectionner
function fract1(X_,Y_,Nmax)
//freeze;
w:=2.7/X_;
h:=-1.87/Y_;
res1:=makelist(-ceiling(X_*Y_/2)-1);
res2:=copy(res1);
Y_:=Y_-1;
for y from 0 to Y_/2 do
z:=0;
od;
res2.append(pixon(x,Y_-y,126*j+2079)); // hpprime: res2.append(pixon_p(x,Y_-y,126*j+2079));
c:=c+w;
od;
od;
return res1,res2; // hpprime: comment on this line, 10 thousand elements maximum
ffunction
