Hello Bernard
Xcas could have a basic analysis of expression in the TOOLBOX menu, similar to what Wolfram does.
Where an equation is entered for example ((x+2)^2)=4 and it shows for example its factorization (with commentary line), expansion, solutions and graph, just by entering the expression in the first line.
See comparative image
Re: basic analysis of expression
Hi
In the expression ((x+2)^2)=4, it can be verified that if the right member is a number, perform the operation [factor, plot, ...] ("pass the member with the opposite sign to the left side"), as other CASs do.
factor( ((x+2)^2)=4 ) → x*(x+4)
plot( ((x+2)^2)=4 )
plot( ((x+2)^2)=4 )
This should be easy to do with a program (script). To add something to Xcas for this seems redundant.
Separating expressions and then joining them is easy through a program, but other CASs do it automatically.
I think many would like this feature by default.
factor( ((x+2)^2) = 4 ) [enter] Run ifactor(4) for integer factorization. =(
factor( ((x+2)^2) - 4 ) [enter] x*(x+4)
This might help: viewtopic.php?f=19&t=2357
