Greek letters for variable names
XcasEngGuy
Message par XcasEngGuy » sam. févr. 12, 2022 7:00 pm
I can't find any information in the Xcas manual about using greek letters for variable names. I know that some are available, like sigma. Is there a way to use the letter Epsilon?
Matt
lukamar
Re: Greek letters for variable names
Message par lukamar » dim. févr. 13, 2022 2:14 pm
"epsilon" and "Gamma" (uppercase gamma) are built-in function names, so they can't be used as symbols. If I'm not mistaken, all other greek symbols which are different from Latin letters (alpha, beta etc.) are available. If you want to use epsilon as a symbol you may use:
eps:=make_symbol("epsilon")
So "eps" will be printed as the greek letter.
XcasEngGuy
Message par XcasEngGuy » dim. févr. 13, 2022 11:22 pm
thanks! exactly what I needed
Matt
(edit) Oops, it didn't work. The initial command works, but when you use the variable it gets evaluated to 1E-12.
Message par parisse » lun. févr. 14, 2022 8:32 am
You can still run eval(eps,1). But that's a little bit tricky...
