Bug in seq comand? (no bug)
Bugs
XcasEngGuy
Message par XcasEngGuy » lun. juin 05, 2023 4:59 pm
I occasionally use seq to extract terms from equations so I can manipulate them individually. I noticed that it substitutes a value into my equation if a variable in my equation matches a variable in the seq command.
Is this a bug? I have not been able to check other commands for similar behavior. I am worried as I use the programming in xcas extensively and this occurs with local variables also.
Matt
Dernière modification par XcasEngGuy le sam. juin 10, 2023 11:42 pm, modifié 1 fois.
Re: Bug in seq comand?
Message par parisse » mar. juin 06, 2023 6:08 pm
You can run op(eq) to extract all the arguments of the root-operator of eq in a sequence (or [op(eq)] in a list).
XcasEngGuy
Message par XcasEngGuy » mar. juin 06, 2023 8:31 pm
That's what I needed.
Thanks again,
Matt
