missing libreadline
Bugs
ftneek
missing libreadline
Message par ftneek » lun. févr. 23, 2026 6:43 am
Hello, I noticed the precompiled mac build is missing libreadline from libs_arm64.
/Applications/usr/bin/icas
dyld[79712]: Library not loaded: @executable_path/../libs_arm64/libreadline.8.2.dylib
  Referenced from: <50E04C8A-7EA6-388F-9941-A7481ED4113D> /Applications/usr/bin/icas
  Reason: tried: '/Applications/usr/libs_arm64/libreadline.8.2.dylib' (no such file)
However if I add the missing file or compile myself, it works fine. Would it be possible to fix?
Re: missing libreadline
Message par parisse » lun. févr. 23, 2026 12:15 pm
Indeed, the library file is missing, this will be fixed for the next binary packages, thanks for pointing. By the way, if it happens that some library files are missing, the easiest way to add them is to install them from an install with brew.
ftneek
Message par ftneek » jeu. févr. 26, 2026 6:14 pm
Much appreciated.
By the way, can files still be downloaded from https://www-fourier.univ-grenoble-alpes ... isse/giac/ ? Lately I get "failed: Connection refused."
wget https://www-fourier.univ-grenoble-alpes.fr/~parisse/giac/xcas_mac.dmg
--2026-02-26 10:07:45--  https://www-fourier.univ-grenoble-alpes.fr/~parisse/giac/xcas_mac.dmg
Resolving www-fourier.univ-grenoble-alpes.fr (www-fourier.univ-grenoble-alpes.fr)... 129.88.208.3
Connecting to www-fourier.univ-grenoble-alpes.fr (www-fourier.univ-grenoble-alpes.fr)|129.88.208.3|:443... failed: Connection refused.
Message par parisse » dim. mars 01, 2026 7:28 pm
Our web server is under heavy load since a couple of months, and is sometimes unavailable. Try again later...
ftneek
Message par ftneek » lun. mars 02, 2026 12:22 am
I was able to download the .dmg file, however when I double click the file a popup window with this message appears:
"The disk image couldn’t be opened
The disk image is corrupted"
Message par parisse » mer. mars 04, 2026 8:52 am
Should be fixed now, I hope.
ftneek
Message par ftneek » ven. mars 06, 2026 5:45 am
Unfortunately, it seems to be the same situation on my end.
Message par parisse » sam. mars 14, 2026 3:34 pm
Might be a cache issue ?
