giac banner should include precise version/platform
dimpase
Message par dimpase » ven. févr. 26, 2021 10:37 am
It is currently not possible to understand what version is giac is run from its banner,e.g.
can anyone guess what version of GIac is run here, and on which platform?
(in fact, this is 1.6.0.47 (with some local patches) on Solaris 11.4,built with gcc 10.2)
$ giac
// Maximum number of parallel threads 96
// Giac share root-directory:/datapool/dima/Sage/sage/local/share/giac/
Help file /datapool/dima/Sage/sage/local/share/giac/doc/en/aide_cas not found
Added 26 synonyms
(c) 2001,2018 B. Parisse & others
May contain BSD licensed software parts (lapack, atlas, tinymt)
Type ?commandname for help
0>> sum(1/(1+x^2),'x=0..infinity')
"Too many recursion levels Error: Bad Argument Value"
// Time 0.01
Another question is - how to debug this? (The same example runs on Linux with gcc 9 just fine)
Re: giac banner should include precise version/platform
Message par parisse » ven. févr. 26, 2021 12:33 pm
I can easily add the version number (1.6.0) but I have no idea how to add the debian subversion -47.
You can debug with gdb, assuming you compiled with -g. Running
grep "Too many recursions" *.cc
will display where the message appears in the source code, then you can set breakpoints where the error is raised. Then from gdb, run
r 'sum(1/(1+x^2),x=0..infinity) '
it should stop at one of the breakpoint, and from there using f 1, f 2, etc. you can trace the calling frames. If you run gdb from the src directory of giac, the .gdbinit file defines a macro v that may be used to see the content of variables of type giac::gen.
