giac 1.7.0-29 on i686
Message par frederic han » dim. sept. 05, 2021 11:02 am
Dear Bernard,
here is a report from Antonio T. (fedora packager for giac) on i686
best Frederic
/bin/sh ../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I..  -DIN_GIAC -I. -I.. -I. -I..       -std=gnu++14 -O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m32 -march=i686 -mtune=generic -msse2 -mfpmath=sse -mstackrealign -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-strict-aliasing -DGIAC_GENERIC_CONSTANTS -DTIMEOUT -DHAVE_LIBMICROPYTHON -fpermissive -DQUICKJS -c -o graphe.lo graphe.cc
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I.. -DIN_GIAC -I. -I.. -I. -I.. -std=gnu++14 -O2 -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m32 -march=i686 -mtune=generic -msse2 -mfpmath=sse -mstackrealign -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-strict-aliasing -DGIAC_GENERIC_CONSTANTS -DTIMEOUT -DHAVE_LIBMICROPYTHON -fpermissive -DQUICKJS -c graphe.cc  -fPIC -DPIC -o .libs/graphe.o
In file included from giacPCH.h:8,
                 from graphe.cc:20:
index.h:33: warning: ignoring '#pragma anon_unions ' [-Wunknown-pragmas]
   33 | #pragma anon_unions
In file included from giacPCH.h:32,
                 from graphe.cc:20:
gen.h: In constructor 'giac::eqwdata::eqwdata(int, int, int, int, const giac::attributs&, const giac::gen&)':
gen.h:1406:15: warning: 'giac::eqwdata::eqw_attributs' will be initialized after [-Wreorder]
 1406 |     attributs eqw_attributs;
gen.h:1399:9: warning:   'int giac::eqwdata::x' [-Wreorder]
 1399 |     int x,y,dx,dy;
gen.h:1407:5: warning:   when initialized here [-Wreorder]
 1407 |     eqwdata(int dxx,int dyy,int xx, int yy,const attributs & a,const gen& gg):g(gg),eqw_attributs(a),x(xx),y(yy),dx(dxx),dy(dyy),selected(false),active(false),hasbaseline(false),modifiable(true),baseline(0) {};
gen.h:1405:10: warning: 'giac::eqwdata::modifiable' will be initialized after [-Wreorder]
 1405 |     bool modifiable;
gen.h:1400:9: warning:   'int giac::eqwdata::baseline' [-Wreorder]
 1400 |     int baseline;
gen.h: In constructor 'giac::eqwdata::eqwdata(int, int, int, int, const giac::attributs&, const giac::gen&, int)':
gen.h:1408:5: warning:   when initialized here [-Wreorder]
 1408 |     eqwdata(int dxx,int dyy,int xx, int yy,const attributs & a,const gen& gg,int mybaseline):g(gg),eqw_attributs(a),x(xx),y(yy),dx(dxx),dy(dyy),selected(false),active(false),hasbaseline(true),modifiable(true),baseline(mybaseline) {};
graphe.cc: In static member function 'static giac::gen giac::graphe::sparse_product_element(const sparsemat&, const sparsemat&, int, int)':
graphe.cc:3947:9: warning: unused variable 'r' [-Wunused-variable]
 3947 |     int r,c;
graphe.cc: In member function 'void giac::graphe::tsp::formulate_mip()':
graphe.cc:10972:46: warning: unused variable 'nrows0' [-Wunused-variable]
10972 |     int nonzeros=0,i,j,k,l,cnt=0,nrows,ncols,nrows0;
graphe.cc: In member function 'giac::graphe::yen::tree_node* giac::graphe::yen::store_path(const ivector&, giac::graphe::yen::tree_node*)':
graphe.cc:13318:11: warning: unused variable 'j' [-Wunused-variable]
13318 |     int i,j,n=path.size();
graphe.cc: In member function 'bool giac::graphe::mvc(giac::graphe::ivector&, int, int, int, double, bool)':
graphe.cc:14717:14: warning: unused variable 'last_cov_size' [-Wunused-variable]
14717 |     int c=-1,last_cov_size=0,cov_size,s,s0,cmp;
graphe.cc:14717:30: warning: unused variable 'cov_size' [-Wunused-variable]
graphe.cc: In member function 'void giac::graphe::mvc_bipartite(const ivector&, const ivector&, giac::graphe::ivector&, int, bool)':
graphe.cc:14890:13: warning: variable 'u' set but not used [-Wunused-but-set-variable]
14890 |         int u,v,w;
graphe.cc: In member function 'void giac::graphe::identify_from_sequences(giac::graphe::ivectors&, int)':
graphe.cc:15690:31: warning: comparison of integer expressions of different signedness: 'int' and 'std::size_t' {aka 'unsigned int'} [-Wsign-compare]
15690 |                     if (maxdeg!=be.count())
graphe.cc:15707:43: error: conversion from 'giac::ulong' {aka 'long unsigned int'} to 'const giac::gen' is ambiguous
15707 |                         G.make_haar_graph(n);
                 from graphe.cc:20:
gen.h:653:5: note: candidate: 'giac::gen::gen(const giac_float&)'
  653 |     gen(const giac_float & f);
gen.h:651:5: note: candidate: 'giac::gen::gen(double)'
  651 |     gen(double d);
gen.h:638:5: note: candidate: 'giac::gen::gen(longlong)'
  638 |     gen(longlong i);
gen.h:637:5: note: candidate: 'giac::gen::gen(long int)'
  637 |     gen(long i);
gen.h:631:5: note: candidate: 'giac::gen::gen(size_t)'
  631 |     gen(size_t i): type(_INT_),subtype(0),val((int)i)  {
gen.h:626:5: note: candidate: 'giac::gen::gen(int)'
  626 |     gen(int i): type(_INT_),subtype(0),val(i) {
graphe.cc:6008:41: note:   initializing argument 1 of 'bool giac::graphe::make_haar_graph(const giac::gen&)'
 6008 | bool graphe::make_haar_graph(const gen &n) {
In file included from index.h:21,
                 from giacPCH.h:8,
                 from graphe.cc:20:
vector.h: In instantiation of 'void std::imvector<_Tp>::resize(std::size_t) [with _Tp = giac::gen; std::size_t = unsigned int]':
graphe.cc:172:15:   required from here
vector.h:301:18: warning: unused variable 'prev' [-Wunused-variable]
  301 |         unsigned prev=_taille==immvector_max?0:_abs(_taille);
make[2]: *** [Makefile:992: graphe.lo] Error 1
Re: giac 1.7.0-29 on i686
Message par parisse » lun. sept. 06, 2021 11:09 am
Can be fixed by
diff graphe.cc graphe.cc~
15707c15707
< 		      G.make_haar_graph(int(n));
sagitter
Message par sagitter » lun. sept. 06, 2021 6:04 pm
Hi Parisse.
I will try your patch soon.
PS. Thank you, Frederic.
sagitter
Message par sagitter » lun. sept. 06, 2021 6:13 pm
Can be fixed by
15707c15707
That line is already in graphe.cc:
$ cat src/graphe.cc | grep G.make_haar_graph
Message par parisse » lun. sept. 06, 2021 6:25 pm
Yes, graphe.cc is the working file (with int), while graphe.cc~ (without) is the non working backup file (from emacs).
sagitter
Message par sagitter » mar. sept. 07, 2021 3:27 pm
Can be fixed by
15707c15707
This patch fixed the error on i686 and ARM.
Thank you.
