giac 1.7.0-29 on i686
Publié : dim. sept. 05, 2021 11:02 am
Dear Bernard,
here is a report from Antonio T. (fedora packager for giac) on i686
best Frederic
best Frederic
/bin/sh ../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I.. -DIN_GIAC -I. -I.. -I. -I.. -std=gnu++14 -O2 -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m32 -march=i686 -mtune=generic -msse2 -mfpmath=sse -mstackrealign -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-strict-aliasing -DGIAC_GENERIC_CONSTANTS -DTIMEOUT -DHAVE_LIBMICROPYTHON -fpermissive -DQUICKJS -c -o graphe.lo graphe.cc
libtool: compile: g++ -DHAVE_CONFIG_H -I. -I.. -DIN_GIAC -I. -I.. -I. -I.. -std=gnu++14 -O2 -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m32 -march=i686 -mtune=generic -msse2 -mfpmath=sse -mstackrealign -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-strict-aliasing -DGIAC_GENERIC_CONSTANTS -DTIMEOUT -DHAVE_LIBMICROPYTHON -fpermissive -DQUICKJS -c graphe.cc -fPIC -DPIC -o .libs/graphe.o
In file included from giacPCH.h:8,
from graphe.cc:20:
index.h:33: warning: ignoring '#pragma anon_unions ' [-Wunknown-pragmas]
33 | #pragma anon_unions
In file included from giacPCH.h:32,
from graphe.cc:20:
gen.h: In constructor 'giac::eqwdata::eqwdata(int, int, int, int, const giac::attributs&, const giac::gen&)':
gen.h:1406:15: warning: 'giac::eqwdata::eqw_attributs' will be initialized after [-Wreorder]
1406 | attributs eqw_attributs;
gen.h:1399:9: warning: 'int giac::eqwdata::x' [-Wreorder]
1399 | int x,y,dx,dy;
gen.h:1407:5: warning: when initialized here [-Wreorder]
1407 | eqwdata(int dxx,int dyy,int xx, int yy,const attributs & a,const gen& gg):g(gg),eqw_attributs(a),x(xx),y(yy),dx(dxx),dy(dyy),selected(false),active(false),hasbaseline(false),modifiable(true),baseline(0) {};
gen.h:1405:10: warning: 'giac::eqwdata::modifiable' will be initialized after [-Wreorder]
1405 | bool modifiable;
gen.h:1400:9: warning: 'int giac::eqwdata::baseline' [-Wreorder]
1400 | int baseline;
gen.h: In constructor 'giac::eqwdata::eqwdata(int, int, int, int, const giac::attributs&, const giac::gen&, int)':
gen.h:1408:5: warning: when initialized here [-Wreorder]
1408 | eqwdata(int dxx,int dyy,int xx, int yy,const attributs & a,const gen& gg,int mybaseline):g(gg),eqw_attributs(a),x(xx),y(yy),dx(dxx),dy(dyy),selected(false),active(false),hasbaseline(true),modifiable(true),baseline(mybaseline) {};
graphe.cc: In static member function 'static giac::gen giac::graphe::sparse_product_element(const sparsemat&, const sparsemat&, int, int)':
graphe.cc:3947:9: warning: unused variable 'r' [-Wunused-variable]
3947 | int r,c;
graphe.cc: In member function 'void giac::graphe::tsp::formulate_mip()':
graphe.cc:10972:46: warning: unused variable 'nrows0' [-Wunused-variable]
10972 | int nonzeros=0,i,j,k,l,cnt=0,nrows,ncols,nrows0;
graphe.cc: In member function 'giac::graphe::yen::tree_node* giac::graphe::yen::store_path(const ivector&, giac::graphe::yen::tree_node*)':
graphe.cc:13318:11: warning: unused variable 'j' [-Wunused-variable]
13318 | int i,j,n=path.size();
graphe.cc: In member function 'bool giac::graphe::mvc(giac::graphe::ivector&, int, int, int, double, bool)':
graphe.cc:14717:14: warning: unused variable 'last_cov_size' [-Wunused-variable]
14717 | int c=-1,last_cov_size=0,cov_size,s,s0,cmp;
graphe.cc:14717:30: warning: unused variable 'cov_size' [-Wunused-variable]
graphe.cc: In member function 'void giac::graphe::mvc_bipartite(const ivector&, const ivector&, giac::graphe::ivector&, int, bool)':
graphe.cc:14890:13: warning: variable 'u' set but not used [-Wunused-but-set-variable]
14890 | int u,v,w;
graphe.cc: In member function 'void giac::graphe::identify_from_sequences(giac::graphe::ivectors&, int)':
graphe.cc:15690:31: warning: comparison of integer expressions of different signedness: 'int' and 'std::size_t' {aka 'unsigned int'} [-Wsign-compare]
15690 | if (maxdeg!=be.count())
graphe.cc:15707:43: error: conversion from 'giac::ulong' {aka 'long unsigned int'} to 'const giac::gen' is ambiguous
15707 | G.make_haar_graph(n);
from graphe.cc:20:
gen.h:653:5: note: candidate: 'giac::gen::gen(const giac_float&)'
653 | gen(const giac_float & f);
gen.h:651:5: note: candidate: 'giac::gen::gen(double)'
651 | gen(double d);
gen.h:638:5: note: candidate: 'giac::gen::gen(longlong)'
638 | gen(longlong i);
gen.h:637:5: note: candidate: 'giac::gen::gen(long int)'
637 | gen(long i);
gen.h:631:5: note: candidate: 'giac::gen::gen(size_t)'
631 | gen(size_t i): type(_INT_),subtype(0),val((int)i) {
gen.h:626:5: note: candidate: 'giac::gen::gen(int)'
626 | gen(int i): type(_INT_),subtype(0),val(i) {
graphe.cc:6008:41: note: initializing argument 1 of 'bool giac::graphe::make_haar_graph(const giac::gen&)'
6008 | bool graphe::make_haar_graph(const gen &n) {
In file included from index.h:21,
from giacPCH.h:8,
from graphe.cc:20:
vector.h: In instantiation of 'void std::imvector<_Tp>::resize(std::size_t) [with _Tp = giac::gen; std::size_t = unsigned int]':
graphe.cc:172:15: required from here
vector.h:301:18: warning: unused variable 'prev' [-Wunused-variable]
301 | unsigned prev=_taille==immvector_max?0:_abs(_taille);
make[2]: *** [Makefile:992: graphe.lo] Error 1
