Error building giac 1.9.0-55 (June 18, 2023) on Linux
Publié : dim. juin 18, 2023 7:25 pm
On same Linux where I build 1.9.0-53 OK few days ago, now I downloaded 1.9.0-55 and it gives an error building. I have not made any changes to the system during this time.
This is on Linux
I have put the config.log and also the full output of the make command in this folder as plain text file to view. If you click on this link, you will see the two plain text files there.
https://12000.org/tmp/giac_june_18_2023
The last error on the screen from the command make is the following:
Thanks
--Nasser
This is on Linux
>uname -a
Linux me-virtualbox 6.1.19-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon Mar 13 12:59:35 UTC 2023 x86_64 GNU/LinuxCode : Tout sélectionner
cat /etc/os-release
NAME="Manjaro Linux"
PRETTY_NAME="Manjaro Linux"
ID=manjaroI have put the config.log and also the full output of the make command in this folder as plain text file to view. If you click on this link, you will see the two plain text files there.
153 | ptr_fun(_Result (*__x)(_Arg1, _Arg2))
poly.h: In instantiation of ‘giac::tensor<T>::tensor(const T&, int) [with T = giac::gen]’:
gen.cc:7933:46: required from here
poly.h:55:172: warning: ‘std::pointer_to_binary_function<_Arg1, _Arg2, _Result> std::ptr_fun(_Result (*)(_Arg1, _Arg2)) [with _Arg1 = const giac::monomial<giac::gen>&; _Arg2 = const giac::monomial<giac::gen>&; _Result = bool]’ is deprecated: use 'std::function' instead [-Wdeprecated-declarations]
55 | strictly_greater), m_is_strictly_greater(std::ptr_fun<const monomial<T> &, const monomial<T> &, bool>(m_lex_is_strictly_greater<T>)) {
/usr/include/c++/12.2.1/bits/stl_function.h:1153:5: note: declared here
1153 | ptr_fun(_Result (*__x)(_Arg1, _Arg2))
poly.h: In instantiation of ‘giac::tensor<T>::tensor(const giac::monomial<T>&) [with T = giac::gen]’:
gen.cc:8437:25: required from here
poly.h:52:193: warning: ‘std::pointer_to_binary_function<_Arg1, _Arg2, _Result> std::ptr_fun(_Result (*)(_Arg1, _Arg2)) [with _Arg1 = const giac::monomial<giac::gen>&; _Arg2 = const giac::monomial<giac::gen>&; _Result = bool]’ is deprecated: use 'std::function' instead [-Wdeprecated-declarations]
52 | strictly_greater), m_is_strictly_greater(std::ptr_fun<const monomial<T> &, const monomial<T> &, bool>(m_lex_is_strictly_greater<T>)) {
make[2]: *** [Makefile:814: gen.lo] Error 1
make[2]: Leaving directory '/home/me/TMP/giac-1.9.0/src'
make[1]: *** [Makefile:413: all-recursive] Error 1
make[1]: Leaving directory '/home/me/TMP/giac-1.9.0'
make: *** [Makefile:342: all] Error 2
Thanks
--Nasser
