syntax error near unexpected token `fi'
sagitter
Message par sagitter » sam. mai 16, 2026 2:54 pm
Hi all.
In Fedora 44 and latest stable giac version, autoconf-2.72 breaks Configure and generates following error:
./configure: line 24045: syntax error near unexpected token `fi'
./configure: line 24045: `        fi'
Log:
+ cd giac-2.0.0
+ /usr/bin/chmod -Rf a+rX,u+w,g-w,o-w .
+ echo 'Patch #0 (giac-fix_bug3022.patch):'
+ /usr/bin/patch --no-backup-if-mismatch -f -p1 -b --suffix .backup --fuzz=0
patching file configure.ac
+ echo 'Patch #1 (giac-iszero.patch):'
patching file src/vecteur.h
Hunk #1 succeeded at 28 (offset 1 line).
+ echo 'Patch #2 (giac-config.patch):'
patching file m4/intdiv0.m4
+ echo 'Patch #3 (giac-1.9.0-fix_micropy_compiler_flags.patch):'
+ /usr/bin/patch --no-backup-if-mismatch -f -p0 -b --suffix .backup --fuzz=0
patching file micropython-1.12/ports/unix/Makefile
patching file micropython-1.12/xcas/Makefile
patching file micropython-1.12/nspire/Makefile
patching file micropython-1.12/numworks/Makefile
+ echo 'Patch #4 (giac-cocoalib.patch):'
Hunk #1 succeeded at 301 (offset 29 lines).
Hunk #1 succeeded at 16946 (offset 284 lines).
patching file src/TmpFGLM.C
patching file src/TmpLESystemSolver.C
+ echo 'Patch #5 (giac-fix_graphe_file.patch):'
patching file src/graphe.cc
Hunk #1 succeeded at 15770 (offset 13 lines).
+ echo 'Patch #6 (giac-pari2.15.patch):'
patching file src/pari.cc
Hunk #1 succeeded at 765 (offset 16 lines).
Hunk #2 succeeded at 900 (offset 16 lines).
+ echo 'Patch #7 (giac-undefine_GLIBCXX_ASSERTIONS.patch):'
patching file src/first.h
Hunk #1 succeeded at 33 (offset 6 lines).
patching file src/vecteur.cc
Hunk #1 succeeded at 8512 (offset 14 lines).
+ echo 'Patch #8 (giac-faking_mkjs.patch):'
patching file src/Makefile.am
Hunk #1 succeeded at 74 (offset 3 lines).
patching file src/Makefile.in
Hunk #1 succeeded at 1462 (offset -8 lines).
+ echo 'Patch #9 (giac-fix_aclocal.patch):'
+ rm -rf intl/eval-plural.h intl/gettextP.h intl/gmo.h intl/hash-string.h intl/loadinfo.h intl/localcharset.h intl/os2compat.h intl/plural-exp.h intl/printf-args.h intl/printf-parse.h intl/relocatable.h intl/vasnprintf.h intl/vasnwprintf.h intl/wprintf-parse.h intl/xsize.h
+ rm -rf 'intl/*.cc'
+ rm -f doc/pari/gphtml
+ rm -f doc/de/texinfo.tex doc/en/texinfo.tex doc/es/texinfo.tex doc/local/texinfo.tex doc/pt/texinfo.tex doc/zh/texinfo.tex
+ rm -f doc/en/giac_us.info doc/es/giac_es.info
+ chmod -x src/Cfg.h src/Editeur.h src/Equation.h src/Graph.h src/Graph3d.h src/Help1.h src/History.h src/Input.h src/Print.h src/Python.h src/Tableur.h src/Xcas1.h src/alg_ext.h src/aspen_translate.h src/bf2gmp.h src/blaswrap.h src/clapack.h src/clapack_new.h src/cocoa.h src/config.h src/csturm.h src/cutils.h src/derive.h src/desolve.h src/dispatch.h src/ezgcd.h src/f2c.h src/fenv.h src/first.h src/fraction.h src/gauss.h src/gausspol.h src/gen.h src/giac.h src/giacPCH.h src/giacintl.h src/gl2ps.h src/global.h src/gmp_replacements.h src/graphe.h src/graphtheory.h src/help.h src/hist.h src/identificateur.h src/ifactor.h src/index.h src/input_lexer.h src/input_parser.h src/intg.h src/intgab.h src/isom.h src/itex2MML.h src/js.h src/k_csdk.h src/k_defs.h src/kdisplay.h src/lexer.h src/lexer_tab_int.h src/libbf.h src/libregexp-opcode.h src/libregexp.h src/libunicode-table.h src/libunicode.h src/lin.h src/list.h src/lpsolve.h src/luabridge.h src/maple.h src/markup.h src/mathml.h src/misc.h src/modfactor.h src/modint.h src/modpoly.h src/monomial.h src/moyal.h src/mp.h src/myostream.h src/nautywrapper.h src/numworks_translate.h src/opengl.h src/optimization.h src/pari.h src/path.h src/permu.h src/plot.h src/plot3d.h src/poly.h src/prog.h src/qjsgiac.h src/qrcodegen.h src/quater.h src/quickjs-atom.h src/quickjs-libc.h src/quickjs-opcode.h src/quickjs.h src/renee.h src/risch.h src/rpn.h src/series.h src/sha256.h src/signalprocessing.h src/softmath.h src/solve.h src/sparse.h src/static.h src/static_extern.h src/static_help.h src/static_lexer.h src/static_lexer_.h src/static_lexer__numworks.h src/static_lexer_numworks.h src/subst.h src/sym2poly.h src/symbolic.h src/tex.h src/threaded.h src/ti89.h src/tinymt32.h src/tinymt32_license.h src/unary.h src/usual.h src/vecteur.h src/vector.h src/y_tab.h
+ chmod -x src/Cfg.cc src/Editeur.cc src/Equation.cc src/Flv_CStyle.cc src/Flv_Data_Source.cc src/Flv_List.cc src/Flv_Style.cc src/Flv_Table.cc src/Flve_Check_Button.cc src/Flve_Combo.cc src/Flve_Input.cc src/Graph.cc src/Graph3d.cc src/Help1.cc src/History.cc src/Input.cc src/Print.cc src/Python.cc src/Tableur.cc src/Xcas1.cc src/aide.cc src/alg_ext.cc src/cas2.cc src/cas2html.cc src/casce.cc src/casctrl.cc src/cocoa.cc src/csturm.cc src/derive.cc src/desolve.cc src/ezgcd.cc src/factor.cc src/find_global_var.cc src/first.cc src/gauss.cc src/gausspol.cc src/gen.cc src/giacnspire.cc src/global.cc src/graphe.cc src/graphtheory.cc src/help.cc src/hevea2mml.cc src/icas.cc src/identificateur.cc src/ifactor.cc src/index.cc src/input_lexer.cc src/input_parser.cc src/integrate.cc src/intg.cc src/intgab.cc src/isom.cc src/kadd.cc src/kdisplay.cc src/lin.cc src/lpsolve.cc src/luabridge.cc src/maple.cc src/markup.cc src/mathml.cc src/misc.cc src/mkjs.cc src/modfactor.cc src/modpoly.cc src/moyal.cc src/mp.cc src/normalize.cc src/opengl.cc src/optimization.cc src/pari.cc src/partfrac.cc src/permu.cc src/plot.cc src/plot3d.cc src/prog.cc src/quater.cc src/renee.cc src/risch.cc src/rpn.cc src/series.cc src/signalprocessing.cc src/softmath.cc src/solve.cc src/sparse.cc src/subst.cc src/sym2poly.cc src/symbolic.cc src/tex.cc src/threaded.cc src/ti89.cc src/tinymt32.cc src/translate.cc src/unary.cc src/usual.cc src/vecteur.cc src/xcas.cc src/xcasce.cc src/xcasctrl.cc
+ find examples -type f -name '*.xws' -exec chmod -x '{}' ';'
+ find examples -type f -name '*.cas' -exec chmod -x '{}' ';'
+ find examples -type f -name '*.cxx' -exec chmod -x '{}' ';'
+ chmod -x examples/lewisw/fermat_gcd_1var examples/lewisw/fermat_gcd_4var examples/lewisw/fermat_gcd_mod_1var examples/lewisw/fermat_gcd_mod_4var
+ find doc -name '*~' -delete
+ sed -i 's|config/texinfo.tex|/usr/share/texlive/texmf-dist/tex/texinfo/texinfo.tex|g' Makefile.in
+ rm -f config/texinfo.tex
+ rm -f 'examples/Exemples/demo/._*'
+ rm -f 'examples/Exemples/analyse/._*'
+ sed -e 's|LIB(blas|LIB(flexiblas|g' -e 's|LIB(lapack|LIB(flexiblas|g' -e 's|-lgslcblas|-lflexiblas|' -i configure.ac
+ cp -p micropython-1.12/LICENSE micropython-1.12/micropython-LICENSE
+ dos2unix configure.ac
dos2unix: converting file configure.ac to Unix format...
+ autoupdate -vf
autoupdate: running: echo dumpdef | /usr/bin/m4 2>/tmp/auz7z8Lq/m4.defs >/dev/null
autom4te: the trace request object is:
autom4te: $VAR1 = bless( [
autom4te:                  '0',
autom4te:                  0,
autom4te:                  [
autom4te:                    '/usr/share/autoconf'
autom4te:                  ],
autom4te:                  [
autom4te:                    '/usr/share/autoconf/m4sugar/m4sugar.m4',
autom4te:                    '/usr/share/autoconf/m4sugar/m4sh.m4',
autom4te:                    '/usr/share/autoconf/autoconf/autoconf.m4',
autom4te:                    'aclocal.m4',
autom4te:                    '/dev/null'
autom4te:                  ],
autom4te:                  {
autom4te:                    'AC_CANONICAL_BUILD' => 1,
autom4te:                    'AC_CANONICAL_HOST' => 1,
autom4te:                    'AC_CANONICAL_SYSTEM' => 1,
autom4te:                    'AC_CANONICAL_TARGET' => 1,
autom4te:                    'AC_CONFIG_AUX_DIR' => 1,
autom4te:                    'AC_CONFIG_FILES' => 1,
autom4te:                    'AC_CONFIG_HEADERS' => 1,
autom4te:                    'AC_CONFIG_LIBOBJ_DIR' => 1,
autom4te:                    'AC_CONFIG_LINKS' => 1,
autom4te:                    'AC_CONFIG_MACRO_DIR_TRACE' => 1,
autom4te:                    'AC_CONFIG_SUBDIRS' => 1,
autom4te:                    'AC_DEFINE_TRACE_LITERAL' => 1,
autom4te:                    'AC_FC_FREEFORM' => 1,
autom4te:                    'AC_FC_PP_DEFINE' => 1,
autom4te:                    'AC_FC_PP_SRCEXT' => 1,
autom4te:                    'AC_FC_SRCEXT' => 1,
autom4te:                    'AC_INIT' => 1,
autom4te:                    'AC_LIBSOURCE' => 1,
autom4te:                    'AC_PROG_LIBTOOL' => 1,
autom4te:                    'AC_REQUIRE_AUX_FILE' => 1,
autom4te:                    'AC_SUBST' => 1,
autom4te:                    'AC_SUBST_TRACE' => 1,
autom4te:                    'AH_OUTPUT' => 1,
autom4te:                    'AM_AUTOMAKE_VERSION' => 1,
autom4te:                    'AM_CONDITIONAL' => 1,
autom4te:                    'AM_ENABLE_MULTILIB' => 1,
autom4te:                    'AM_EXTRA_RECURSIVE_TARGETS' => 1,
autom4te:                    'AM_GNU_GETTEXT' => 1,
autom4te:                    'AM_GNU_GETTEXT_INTL_SUBDIR' => 1,
autom4te:                    'AM_INIT_AUTOMAKE' => 1,
autom4te:                    'AM_MAINTAINER_MODE' => 1,
autom4te:                    'AM_MAKEFILE_INCLUDE' => 1,
autom4te:                    'AM_NLS' => 1,
autom4te:                    'AM_PATH_GUILE' => 1,
autom4te:                    'AM_POT_TOOLS' => 1,
autom4te:                    'AM_PROG_AR' => 1,
autom4te:                    'AM_PROG_CC_C_O' => 1,
autom4te:                    'AM_PROG_CXX_C_O' => 1,
autom4te:                    'AM_PROG_F77_C_O' => 1,
autom4te:                    'AM_PROG_FC_C_O' => 1,
autom4te:                    'AM_PROG_LIBTOOL' => 1,
autom4te:                    'AM_PROG_MKDIR_P' => 1,
autom4te:                    'AM_PROG_MOC' => 1,
autom4te:                    'AM_SILENT_RULES' => 1,
autom4te:                    'AM_XGETTEXT_OPTION' => 1,
autom4te:                    'AU_DEFINE' => 1,
autom4te:                    'GTK_DOC_CHECK' => 1,
autom4te:                    'IT_PROG_INTLTOOL' => 1,
autom4te:                    'LT_CONFIG_LTDL_DIR' => 1,
autom4te:                    'LT_INIT' => 1,
autom4te:                    'LT_SUPPORTED_TAG' => 1,
autom4te:                    '_AM_COND_ELSE' => 1,
autom4te:                    '_AM_COND_ENDIF' => 1,
autom4te:                    '_AM_COND_IF' => 1,
autom4te:                    '_AM_MAKEFILE_INCLUDE' => 1,
autom4te:                    '_AM_SUBST_NOTMAKE' => 1,
autom4te:                    '_LT_AC_TAGCONFIG' => 1,
autom4te:                    '_m4_warn' => 1,
autom4te:                    'define' => 1,
autom4te:                    'include' => 1,
autom4te:                    'm4_define' => 1,
autom4te:                    'm4_include' => 1,
autom4te:                    'm4_pattern_allow' => 1,
autom4te:                    'm4_pattern_forbid' => 1,
autom4te:                    'm4_sinclude' => 1,
autom4te:                    'sinclude' => 1
autom4te:                  }
autom4te:                ], 'Autom4te::Request' );
autom4te: running: /usr/bin/m4 --nesting-limit=1024 --gnu --include=/usr/share/autoconf --debug=aflq --fatal-warning --debugfile=autom4te.cache/traces.0t --trace=AC_CANONICAL_BUILD --trace=AC_CANONICAL_HOST --trace=AC_CANONICAL_SYSTEM --trace=AC_CANONICAL_TARGET --trace=AC_CONFIG_AUX_DIR --trace=AC_CONFIG_FILES --trace=AC_CONFIG_HEADERS --trace=AC_CONFIG_LIBOBJ_DIR --trace=AC_CONFIG_LINKS --trace=AC_CONFIG_MACRO_DIR_TRACE --trace=AC_CONFIG_SUBDIRS --trace=AC_DEFINE_TRACE_LITERAL --trace=AC_FC_FREEFORM --trace=AC_FC_PP_DEFINE --trace=AC_FC_PP_SRCEXT --trace=AC_FC_SRCEXT --trace=AC_INIT --trace=AC_LIBSOURCE --trace=AC_PROG_LIBTOOL --trace=AC_REQUIRE_AUX_FILE --trace=AC_SUBST --trace=AC_SUBST_TRACE --trace=AH_OUTPUT --trace=AM_AUTOMAKE_VERSION --trace=AM_CONDITIONAL --trace=AM_ENABLE_MULTILIB --trace=AM_EXTRA_RECURSIVE_TARGETS --trace=AM_GNU_GETTEXT --trace=AM_GNU_GETTEXT_INTL_SUBDIR --trace=AM_INIT_AUTOMAKE --trace=AM_MAINTAINER_MODE --trace=AM_MAKEFILE_INCLUDE --trace=AM_NLS --trace=AM_PATH_GUILE --trace=AM_POT_TOOLS --trace=AM_PROG_AR --trace=AM_PROG_CC_C_O --trace=AM_PROG_CXX_C_O --trace=AM_PROG_F77_C_O --trace=AM_PROG_FC_C_O --trace=AM_PROG_LIBTOOL --trace=AM_PROG_MKDIR_P --trace=AM_PROG_MOC --trace=AM_SILENT_RULES --trace=AM_XGETTEXT_OPTION --trace=AU_DEFINE --trace=GTK_DOC_CHECK --trace=IT_PROG_INTLTOOL --trace=LT_CONFIG_LTDL_DIR --trace=LT_INIT --trace=LT_SUPPORTED_TAG --trace=_AM_COND_ELSE --trace=_AM_COND_ENDIF --trace=_AM_COND_IF --trace=_AM_MAKEFILE_INCLUDE --trace=_AM_SUBST_NOTMAKE --trace=_LT_AC_TAGCONFIG --trace=_m4_warn --trace=define --trace=include --trace=m4_define --trace=m4_include --trace=m4_pattern_allow --trace=m4_pattern_forbid --trace=m4_sinclude --trace=sinclude /usr/share/autoconf/m4sugar/m4sugar.m4 /usr/share/autoconf/m4sugar/m4sh.m4 /usr/share/autoconf/autoconf/autoconf.m4 aclocal.m4 /dev/null > autom4te.cache/output.0t
aclocal.m4:17: warning: this file was generated for autoconf 2.69.
You have another version of autoconf.  It may work, but is not guaranteed to.
If you have problems, you may need to regenerate the build system entirely.
To do so, use the procedure documented by the package, typically 'autoreconf'.
autom4te: formatting traces for '/tmp/am4tftuW9C/warnings': _m4_warn
autom4te: reading /tmp/am4tftuW9C/warnings
autom4te: formatting traces for '-': AU_DEFINE, define, m4_define
autoupdate: running: /usr/bin/autom4te --language=autoconf --force --verbose --include=/usr/share/autoconf --trace AU_DEFINE:'_au_defun(@<:@$1@:>@,
autoupdate: @<:@$2@:>@)' --melt /dev/null >/tmp/auz7z8Lq/au.m4
autom4te:                  '0',
autom4te:                  0,
autom4te:                  [
autom4te:                  ],
autom4te:                  [
autom4te:                  ],
autom4te:                  {
autom4te:                  }
autom4te: formatting traces for '/tmp/am4tSFaYOa/warnings': _m4_warn
autom4te: reading /tmp/am4tSFaYOa/warnings
autoupdate: running: /usr/bin/m4 --include=/tmp/auz7z8Lq --include=/usr/share/autoconf /tmp/auz7z8Lq/input.m4 > /tmp/auz7z8Lq/updated
autoupdate: 'configure.ac' is updated
+ autoreconf -if
Copying file intl/eval-plural.h
Copying file intl/gettextP.h
Copying file intl/gmo.h
Copying file intl/hash-string.h
Copying file intl/loadinfo.h
Copying file intl/localcharset.h
Copying file intl/localename.c
Copying file intl/os2compat.h
Copying file intl/plural-exp.h
Copying file intl/printf-args.h
Copying file intl/printf-parse.h
Copying file intl/relocatable.h
Copying file intl/vasnprintf.h
Copying file intl/vasnwprintf.h
Copying file intl/wprintf-parse.h
Copying file intl/xsize.h
Copying file po/Makefile.in.in
Copying file po/Makevars.template
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, 'config'.
libtoolize: copying file 'config/ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIRS, 'm4'.
libtoolize: copying file 'm4/libtool.m4'
libtoolize: copying file 'm4/ltoptions.m4'
libtoolize: copying file 'm4/ltsugar.m4'
libtoolize: copying file 'm4/ltversion.m4'
libtoolize: copying file 'm4/lt~obsolete.m4'
configure.ac:40: warning: AC_PROG_LEX without either yywrap or noyywrap is obsolete
./lib/autoconf/programs.m4:743: _AC_PROG_LEX is expanded from...
./lib/autoconf/programs.m4:736: AC_PROG_LEX is expanded from...
aclocal.m4:631: AM_PROG_LEX is expanded from...
configure.ac:40: the top level
configure.ac:572: warning: The macro 'AC_OUTPUT_COMMANDS' is obsolete.
configure.ac:572: You should run autoupdate.
./lib/autoconf/status.m4:1025: AC_OUTPUT_COMMANDS is expanded from...
m4/po.m4:23: AM_PO_SUBDIRS is expanded from...
m4/gettext.m4:57: AM_GNU_GETTEXT is expanded from...
configure.ac:572: the top level
configure.ac:572: warning: The macro 'AC_HEADER_STDC' is obsolete.
./lib/autoconf/headers.m4:663: AC_HEADER_STDC is expanded from...
m4/gettext.m4:359: AM_INTL_SUBDIR is expanded from...
configure.ac:572: warning: The macro 'AC_TRY_COMPILE' is obsolete.
./lib/autoconf/general.m4:2845: AC_TRY_COMPILE is expanded from...
lib/m4sugar/m4sh.m4:690: _AS_IF_ELSE is expanded from...
lib/m4sugar/m4sh.m4:697: AS_IF is expanded from...
./lib/autoconf/general.m4:2249: AC_CACHE_VAL is expanded from...
./lib/autoconf/general.m4:2270: AC_CACHE_CHECK is expanded from...
m4/signed.m4:9: bh_C_SIGNED is expanded from...
configure.ac:572: warning: The macro 'AC_TRY_LINK' is obsolete.
./lib/autoconf/general.m4:2918: AC_TRY_LINK is expanded from...
m4/longlong.m4:11: gl_AC_TYPE_LONG_LONG is expanded from...
m4/longdouble.m4:11: gt_TYPE_LONGDOUBLE is expanded from...
m4/wchar_t.m4:11: gt_TYPE_WCHAR_T is expanded from...
m4/wint_t.m4:11: gt_TYPE_WINT_T is expanded from...
m4/inttypes_h.m4:12: gl_AC_HEADER_INTTYPES_H is expanded from...
m4/stdint_h.m4:12: gl_AC_HEADER_STDINT_H is expanded from...
m4/intmax.m4:11: gt_TYPE_INTMAX_T is expanded from...
configure.ac:572: warning: The macro 'AC_TRY_RUN' is obsolete.
./lib/autoconf/general.m4:2995: AC_TRY_RUN is expanded from...
m4/printf-posix.m4:11: gt_PRINTF_POSIX is expanded from...
m4/intdiv0.m4:9: gt_INTDIV0 is expanded from...
m4/ulonglong.m4:11: gl_AC_TYPE_UNSIGNED_LONG_LONG is expanded from...
m4/uintmax_t.m4:14: gl_AC_TYPE_UINTMAX_T is expanded from...
m4/inttypes.m4:12: gt_HEADER_INTTYPES_H is expanded from...
m4/inttypes-pri.m4:12: gt_INTTYPES_PRI is expanded from...
configure.ac:572: warning: The macro '_AC_COMPUTE_INT' is obsolete.
./lib/autoconf/general.m4:3374: _AC_COMPUTE_INT is expanded from...
m4/size_max.m4:9: gl_SIZE_MAX is expanded from...
m4/xsize.m4:7: gl_XSIZE is expanded from...
m4/gettext.m4:486: gt_INTL_MACOSX is expanded from...
m4/gettext.m4:530: gt_CHECK_DECL is expanded from...
m4/iconv.m4:20: AM_ICONV_LINK is expanded from...
m4/iconv.m4:75: AM_ICONV is expanded from...
m4/codeset.m4:9: AM_LANGINFO_CODESET is expanded from...
m4/lcmessage.m4:21: gt_LC_MESSAGES is expanded from...
configure.ac:32: installing 'config/compile'
configure.ac:27: installing 'config/missing'
doc/el/Makefile.am:3: warning: suffix '.texinfo' for Texinfo files is discouraged; use '.texi' instead
doc/el/Makefile.am:3: installing 'config/texinfo.tex'
doc/en/Makefile.am:13: warning: suffix '.texinfo' for Texinfo files is discouraged; use '.texi' instead
doc/es/Makefile.am:1: warning: suffix '.texinfo' for Texinfo files is discouraged; use '.texi' instead
src/Makefile.am: installing 'config/depcomp'
+ RPM_EC=0
++ jobs -p
+ exit 0
Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.BSUgmx
+ umask 022
+ cd /home/sagitter/rpmbuild/BUILD/giac-2.0.0.21-build
+ CFLAGS='-O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64 -march=x86-64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -mtls-dialect=gnu2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer  '
+ export CFLAGS
+ CXXFLAGS='-O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64 -march=x86-64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -mtls-dialect=gnu2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer  '
+ export CXXFLAGS
+ FFLAGS='-O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64 -march=x86-64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -mtls-dialect=gnu2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -I/usr/lib64/gfortran/modules  '
+ export FFLAGS
+ FCFLAGS='-O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64 -march=x86-64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -mtls-dialect=gnu2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -I/usr/lib64/gfortran/modules  '
+ export FCFLAGS
+ VALAFLAGS=-g
+ export VALAFLAGS
+ RUSTFLAGS='-Copt-level=3 -Cdebuginfo=2 -Ccodegen-units=1 -Cstrip=none -Cforce-frame-pointers=yes -Clink-arg=-specs=/usr/lib/rpm/redhat/redhat-package-notes --cap-lints=warn'
+ export RUSTFLAGS
+ LDFLAGS='-Wl,-z,relro -Wl,--as-needed  -Wl,-z,pack-relative-relocs -Wl,-z,now -specs=/usr/lib/rpm/redhat/redhat-hardened-ld -specs=/usr/lib/rpm/redhat/redhat-hardened-ld-errors -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -Wl,--build-id=sha1 -specs=/usr/lib/rpm/redhat/redhat-package-notes  '
+ export LDFLAGS
+ LT_SYS_LIBRARY_PATH=/usr/lib64:
+ export LT_SYS_LIBRARY_PATH
+ CC=gcc
+ export CC
+ CXX=g++
+ export CXX
+ cd giac-2.0.0
++ echo '-O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64 -march=x86-64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -mtls-dialect=gnu2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer  '
++ /usr/bin/sed -e s/-Werror=format-security/-Wno-error=format-security/
+ OPT_FLAGS='-O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Wno-error=format-security -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64 -march=x86-64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -mtls-dialect=gnu2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer  '
+ export 'CXXFLAGS=-O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Wno-error=format-security -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64 -march=x86-64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -mtls-dialect=gnu2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer   -fpermissive -std=gnu++17'
+ CXXFLAGS='-O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Wno-error=format-security -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64 -march=x86-64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -mtls-dialect=gnu2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer   -fpermissive -std=gnu++17'
+ export 'CFLAGS_FEDORA=-O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Wno-error=format-security -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64 -march=x86-64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -mtls-dialect=gnu2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer   -std=gnu17'
+ CFLAGS_FEDORA='-O2  -fexceptions -g -grecord-gcc-switches -pipe -Wall -Wno-error=format-security -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1  -m64 -march=x86-64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -mtls-dialect=gnu2 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer   -std=gnu17'
+ export LIBFLTK=GIAC
+ LIBFLTK=GIAC
+ export CFLAGS
+ export CXXFLAGS
+ export FFLAGS
+ export FCFLAGS
+ VALAFLAGS=-g
+ export VALAFLAGS
+ export RUSTFLAGS
+ export LDFLAGS
+ CC=gcc
+ export CC
+ CXX=g++
+ export CXX
+ '[' x '!=' x ']'
+ '[' 1 = 1 ']'
+++ dirname ./configure
++ find . -name config.guess -o -name config.sub
+ for i in $(find $(dirname ./configure) -name config.guess -o -name config.sub)
++ basename ./config/config.guess
+ '[' -f /usr/lib/rpm/redhat/config.guess ']'
+ /usr/bin/rm -f ./config/config.guess
+ /usr/bin/cp -fv /usr/lib/rpm/redhat/config.guess ./config/config.guess
'/usr/lib/rpm/redhat/config.guess' -> './config/config.guess'
++ basename ./config/config.sub
+ '[' -f /usr/lib/rpm/redhat/config.sub ']'
+ /usr/bin/rm -f ./config/config.sub
+ /usr/bin/cp -fv /usr/lib/rpm/redhat/config.sub ./config/config.sub
'/usr/lib/rpm/redhat/config.sub' -> './config/config.sub'
++ basename ./config.guess
+ /usr/bin/rm -f ./config.guess
+ /usr/bin/cp -fv /usr/lib/rpm/redhat/config.guess ./config.guess
'/usr/lib/rpm/redhat/config.guess' -> './config.guess'
++ basename ./config.sub
+ /usr/bin/rm -f ./config.sub
+ /usr/bin/cp -fv /usr/lib/rpm/redhat/config.sub ./config.sub
'/usr/lib/rpm/redhat/config.sub' -> './config.sub'
+ '[' 1 = 1 ']'
+ '[' x '!=' 'x-Wl,-z,now -specs=/usr/lib/rpm/redhat/redhat-hardened-ld -specs=/usr/lib/rpm/redhat/redhat-hardened-ld-errors' ']'
++ find . -name ltmain.sh
+ for i in $(find . -name ltmain.sh)
+ /usr/bin/sed -i.backup -e 's~compiler_flags=$~compiler_flags="-Wl,-z,now -specs=/usr/lib/rpm/redhat/redhat-hardened-ld -specs=/usr/lib/rpm/redhat/redhat-hardened-ld-errors"~' ./config/ltmain.sh
++ grep -q runstatedir=DIR ./configure
++ echo --runstatedir=/run
+ ./configure --build=x86_64-redhat-linux --host=x86_64-redhat-linux --program-prefix= --disable-dependency-tracking --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/bin --sysconfdir=/etc --datadir=/usr/share --includedir=/usr/include --libdir=/usr/lib64 --libexecdir=/usr/libexec --localstatedir=/var --runstatedir=/run --sharedstatedir=/var/lib --mandir=/usr/share/man --infodir=/usr/share/info --enable-static=yes --with-included-gettext=no --enable-nls=no --enable-tommath=no --enable-debug=no --enable-gc=no --enable-sscl=no --enable-dl=yes --enable-gsl=yes --enable-lapack=yes --enable-pari=yes --enable-ntl=yes --enable-gmpxx=yes --enable-cocoa=autodetect --enable-gui=yes --disable-rpath --enable-fltk=yes FLTK_LIB_DIR=/usr/lib64 'FLTK_LIBS=-lfltk_images -lfltk_gl -lfltk'
checking for a BSD-compatible install... /usr/bin/install -c
checking whether sleep supports fractional seconds... yes
checking filesystem timestamp resolution... 0.01
checking whether build environment is sane... yes
checking for a race-free mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking xargs -n works... yes
checking whether UID '1000' is supported by ustar format... yes
checking whether GID '1000' is supported by ustar format... yes
checking how to create a ustar tar archive... gnutar
checking for x86_64-redhat-linux-gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether the compiler supports GNU C... yes
checking whether gcc accepts -g... yes
checking for gcc option to enable C11 features... none needed
checking whether gcc understands -c and -o together... yes
checking whether make supports the include directive... yes (GNU style)
checking dependency style of gcc... none
checking whether ln -s works... yes
checking whether the compiler supports GNU C++... yes
checking whether g++ accepts -g... yes
checking for g++ option to enable C++11 features... none needed
checking dependency style of g++... none
checking how to run the C++ preprocessor... g++ -E
checking build system type... x86_64-redhat-linux-gnu
checking host system type... x86_64-redhat-linux-gnu
checking how to print strings... printf
checking for a sed that does not truncate output... /usr/bin/sed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-redhat-linux-gnu file names to x86_64-redhat-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-redhat-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for file... file
checking for x86_64-redhat-linux-objdump... no
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for x86_64-redhat-linux-dlltool... no
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for x86_64-redhat-linux-ranlib... no
checking for ranlib... ranlib
checking for x86_64-redhat-linux-ar... no
checking for ar... ar
checking for archiver @FILE support... @
checking for x86_64-redhat-linux-strip... no
checking for strip... strip
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /usr/bin/dd
checking how to truncate binary pipes... /usr/bin/dd bs=4096 count=1
checking for x86_64-redhat-linux-mt... no
checking for mt... no
checking if : is a manifest tool... no
checking for stdio.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for strings.h... yes
checking for sys/stat.h... yes
checking for sys/types.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... no
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking for bison... bison -y
checking for flex... flex
checking for lex output file root... lex.yy
checking for lex library... none needed
checking for library containing yywrap... no
checking whether yytext is a pointer... yes
checking whether byte ordering is bigendian... no
checking for standard C++ header files... yes
checking for regex... yes
checking for tgammaf... yes
checking for gmp.h... yes
checking for main in -lgmp... yes
checking for mpfr.h... yes
checking for main in -lmpfr... yes
checking for mpfr_set_str_raw... no
checking for mpfi.h... yes
checking for main in -lmpfi... yes
checking for mps/mps.h... no
checking for gmpxx.h... yes
checking for main in -lgmpxx... yes
checking for ecm.h... yes
checking for main in -lecm... yes
checking for bern_rat.h... no
checking for NTL/ZZ.h... yes
checking for main in -lntl... yes
checking for pari/pari.h... yes
checking for main in -lpari... yes
./configure: line 20576: xno: command not found
checking for main in -lm... yes
checking for png.h... yes
checking for library containing png_sig_cmp... -lpng16
checking for dlopen in -ldl... yes
checking size of void *... 8
checking size of int... 4
checking size of long... 8
checking size of long long... 8
checking for gsl/gsl_blas.h... yes
checking for gsl/gsl_eigen.h... yes
checking for main in -lgslcblas... yes
checking for gsl_sf_gamma in -lgsl... yes
checking for main in -lgfortran... yes
checking for main in -lflexiblas... yes
checking for main in -lflexiblas... (cached) yes
checking for CoCoA/BigInt.H... yes
checking for main in -lcocoa... yes
checking for ao/ao.h... yes
checking for main in -lao... yes
checking for glpk.h... yes
checking for main in -lglpk... yes
checking for samplerate.h... yes
checking for main in -lsamplerate... yes
checking for curl/curl.h... yes
checking for main in -lcurl... yes
checking for tgetent... no
checking for tgetent in -lncurses... yes
checking for readline/readline.h... yes
checking for readline/history.h... yes
checking for version of libreadline... yes
checking for readline in -lreadline... yes
error: Bad exit status from /var/tmp/rpm-tmp.BSUgmx (%build)
Dernière modification par sagitter le sam. mai 16, 2026 5:15 pm, modifié 1 fois.
mailto: sagitter 'at' fedoraproject 'dot' org
https://fedoraproject.org/wiki/User:Sagitter
sagitter
Re: syntax error near unexpected token `fi'
Message par sagitter » sam. mai 16, 2026 4:51 pm
This error could be created from this patch: viewtopic.php?f=4&t=3022#p13310
Message par parisse » mar. mai 19, 2026 8:10 am
I can not reproduce with the configure shell script that is in the current tarball, it was generated with autoconf 2.69: https://www-fourier.univ-grenoble-alpes ... /configure
Perhaps an issue with a newer version of autoconf? Is there any reason to regenerate the configure script?
sagitter
Message par sagitter » mer. mai 20, 2026 6:27 pm
Make recalls aclocal-1.16 and automake-1.16 which are not available in Fedora
Message par parisse » jeu. mai 21, 2026 1:27 pm
There is indeed a misplaced fi in configure.ac, the fixed version is
https://www-fourier.univ-grenoble-alpes ... nfigure.ac
I have checked on my side, it seems ok. Does it fix your issue?
sagitter
Message par sagitter » mer. juin 10, 2026 8:04 pm
Sorry for late reply.
Yes, it's working now.
