pari.cc: In function 'void giac::do_giac_pari_init(long int)':
pari.cc:94:25: error: 'flisexpr' was not declared in this scope
     flisexpr("[x,y,z,t]");
#define flisexpr gp_read_str
PASS: chk_limit
255,256c255,256
< 1/20736*(12*x+12*((i)/sqrt(2)-1/sqrt(2)))*(12*x+12*(-(i)/sqrt(2)-1/sqrt(2)))*(12*x+12*((i)/sqrt(2)+1/sqrt(2)))*(12*x+12*(-(i)/sqrt(2)+1/sqrt(2))),
> 1/20736*(12*x+12*(-1/sqrt(2)+(i)/sqrt(2)))*(12*x+12*(-1/sqrt(2)-(i)/sqrt(2)))*(12*x+12*(1/sqrt(2)+(i)/sqrt(2)))*(12*x+12*(1/sqrt(2)-(i)/sqrt(2))),
FAIL: chk_cas
PASS: chk_geo
PASS: chk_fhan11
131c131
< % abs acos acosh apply arg asin asinh atan atanh binomial bitand bitor bitxor break ceil charpoly concat conj content cos cosh default divisors erfc eval exp factor factorial floor frac gcd global hilbert imag input isprime kill lcm length local matrix max min next nextprime norm print read real round select shift sign simplify sin sinh solve sqrt subst sum tan tanh taylor trace truncate type until valuation vector version write
> % abs acos acosh apply arg asin asinh atan atanh binomial bitand bitor bitxor break ceil charpoly concat conj content cos cosh default divisors erfc eval exp factor factorial floor frac gcd global hilbert imag isprime kill lcm length local matrix max min next nextprime norm print real round select shift sign simplify sin sinh solve sqrt subst sum tan tanh taylor trace truncate type until valuation vector version write
FAIL: chk_fhan12
FAIL: chk_cas
regroup(factor(x^4+1,exp(i*pi/4))-'1/20736*(12*x+12*(-1/sqrt(2)+(i)/sqrt(2)))*(12*x+12*(-1/sqrt(2)-(i)/sqrt(2)))*(12*x+12*(1/sqrt(2)+(i)/sqrt(2)))*(12*x+12*(1/sqrt(2)-(i)/sqrt(2)))')
