Make it possible to build giac without fltk again
Publié : dim. juin 25, 2017 10:00 pm
par fbissey
I am working on the gentoo ebuild for giac. This is somewhat related to the post of my debian colleagues in
http://xcas.e.ujf-grenoble.fr/XCAS/view ... f=4&t=1812 but slightly more pointy.
In 1.2.3-51 it is impossible to build giac without fltk even if you pass --disable-gui to configure. The first piece of code that make it choke is
bool has_graph3d(Fl_Widget * widget){
#ifdef HAVE_LIBFLTK
Fl_Group * g=dynamic_cast<Fl_Group *>(widget);
in src/Xcas.cc where, as one can see, some fltk code is outside the fltk guard. There may be other occurrences. I won't update the package for Gentoo until this is fixed one way or another. The package included in sage cannot be updated either since sage doesn't ship or require fltk at this stage.
Re: Make it possible to build giac without fltk again
Publié : lun. juin 26, 2017 12:05 pm
Should be fixed with 1.2.3-53 just released.
Publié : mar. juin 27, 2017 12:03 pm
1.2.3-55 should be used, 1.2.3-53 has incompatibilites with giacpy.
Publié : jeu. juil. 20, 2017 8:06 am
par fbissey
Thanks. I have to check my forum settings since your update didn't reach me.
Publié : ven. juil. 21, 2017 11:11 am
par fbissey
I have just tried 1.2.3-57 with sage and the results are surprising
fbissey@moonloop ~ $ sage -t --long /usr/lib64/python2.7/site-packages/sage/interfaces/giac.py
too many failed tests, not using stored timings
Running doctests with ID 2017-07-21-22-04-37-6122100c.
Using --optional=optional,sage
Doctesting 1 file.
File "/usr/lib64/python2.7/site-packages/sage/interfaces/giac.py", line 705, in sage.interfaces.giac.Giac._equality_symbol
Failed example:
giac(2) == giac(2)
Expected:
True
Got:
False
File "/usr/lib64/python2.7/site-packages/sage/interfaces/giac.py", line 721, in sage.interfaces.giac.Giac._true_symbol
Failed example:
giac(2) == giac(2)
Expected:
True
Got:
False
File "/usr/lib64/python2.7/site-packages/sage/interfaces/giac.py", line 884, in sage.interfaces.giac.GiacElement.__cmp__
Failed example:
a == b
Expected:
True
Got:
False
File "/usr/lib64/python2.7/site-packages/sage/interfaces/giac.py", line 886, in sage.interfaces.giac.GiacElement.__cmp__
Failed example:
a == 5
Expected:
True
Got:
False
File "/usr/lib64/python2.7/site-packages/sage/interfaces/giac.py", line 894, in sage.interfaces.giac.GiacElement.__cmp__
Failed example:
a < c
Expected:
False
Got:
True
File "/usr/lib64/python2.7/site-packages/sage/interfaces/giac.py", line 896, in sage.interfaces.giac.GiacElement.__cmp__
Failed example:
a < 6
Expected:
True
Got:
False
File "/usr/lib64/python2.7/site-packages/sage/interfaces/giac.py", line 898, in sage.interfaces.giac.GiacElement.__cmp__
Failed example:
c <= a
Expected:
True
Got:
False
some subtle changes seem to break sage's interface to icas.
Publié : mar. août 01, 2017 2:15 pm
Hi Francois,
it seems that the string representation of the true symbol has recently changed from
to a (LANG dependent) string
or
but in sage the giac pexpect interface: sage/interfaces/giac.py
uses the function _true_symbol
I have tried with (replacing 1 by true):
def _true_symbol(self):
Returns the symbol used for truth in Giac.
EXAMPLES::
sage: giac._true_symbol()
'true'
sage: giac(2) == giac(2)
True
return 'true'
and it looks to solve this problem. (even if my lang is french)
NB: giacpy and giacpy_sage doesn't have this problem
Publié : ven. août 04, 2017 8:10 am
par fbissey
Good catch Frederic. It may end up going the way gap did go recently.
