graph theory commands for Giac
Re: graph theory commands for Giac
Message par parisse » lun. déc. 31, 2018 7:37 am
Works fine here. Perhaps it also crashes with other commands for you, some versions of windows are incompatible with xcas 64 bits.
lukamar
Message par lukamar » lun. déc. 31, 2018 7:45 am
I'll try windows 10 at work next week. Do you plan updating the 32-bit version?
Message par parisse » lun. déc. 31, 2018 10:27 am
Yes, but I wait for complete stabilization because it requires my old mac.
Message par parisse » lun. déc. 31, 2018 8:21 pm
Your changes should be in the debian 9 package (1.5.0-33).
lukamar
Message par lukamar » mar. janv. 01, 2019 10:48 pm
I have a few additional changes:
* there was a bug in circular drawing algorithm, the hull vertices weren't scanned properly, it's now fixed
* added a new command truncate_graph for truncating biconnected planar graphs
* docs were updated
[Edit] hardcoded another 10 special graphs and updated the docs
Message par parisse » mer. janv. 02, 2019 11:09 am
Thanks! Will be in 1.5.0-35.
lukamar
Message par lukamar » mer. janv. 02, 2019 8:12 pm
Thank you. In the meantime I committed a fix to the Errera graph definition and added examples for the parametrized st-ordering to the manual.
Message par parisse » mer. janv. 02, 2019 9:05 pm
It gives a warning
graphe.cc:565: warning: extended initializer lists only available with -std=c++0x or -std=gnu++0x
I believe there is a = missing.
lukamar
Message par lukamar » mer. janv. 02, 2019 11:01 pm
You're right, fixed!
[Edit] I've also added 4 more special graphs: Balaban 10- and 11-cage, the F26A graph and the Tutte graph.
lukamar
Message par lukamar » sam. janv. 05, 2019 12:25 pm
A new update:
* implemented graph condensation, the new command is called "condensation"
* implemented Tarjan's elementary circuit finding algorithm for digraphs, the new command is called "find_cycles"
lukamar
Message par lukamar » lun. janv. 07, 2019 3:02 pm
I have tested Xcas64 in Windows 10, nauty works fine here :)
[Edit] Unfortunately, it crashes on Windows 8...
lukamar
Message par lukamar » mer. janv. 09, 2019 12:36 pm
An update: implemented Yen's algorithm for k shortest paths (the command "kspaths").
jocaps
Message par jocaps » jeu. janv. 10, 2019 4:25 pm
Hi,
Just want to bump here. I don't know the intricacies of your developments and I don't know if it helps. Maybe its worth mentioning that I compile nauty for windows (independent of giac) as a separate dll (in fact I compile with msvc which is rarely possible for math libraries). So I suppose your issues are more related on how you use it in giac?
Jose
lukamar
Message par lukamar » jeu. janv. 10, 2019 5:55 pm
Hello Jose,
That could be. However, I don't have any problems with nauty in Giac when using my Linux system. I tried to be extra careful when coding the nauty wrapper, doing it exactly as explained by McKay in the nauty docs, and I can't find anything wrong in the code. (Maybe I don't see a bug?) Furthermore, as you've pointed out yourself, nauty itself compiles fine on Windows. Therefore I'm inclined to think it's rather an issue with cross-compiling Giac/Xcas, but don't have a clue where, how and why... Perhaps Bernard can help pinpointing the cause?
Note that Xcas64 (with nauty) works well in Windows 10, but the same version is crashing in Windows 8 even at very simple commandlines, such as solving a quadratic equation.
Luka
compsystems
Message par compsystems » ven. janv. 11, 2019 12:28 am
xcas starts well in windows10, but when executing certain commands the application is closed, unfortunately, there is not an error message to send it to the developer, to see why it happens, I have seen other applications that before closing show or deploy an error message, this message can this be incorporated into Xcas?
