Effectivement, bien souvent ca n'est pas des erreurs mathematiques mais j'ai l'impression que certaines de tes sorties de references ne correspondent plus a la 1.1.1?
Par exemple je viens d'essayer avec ton binaire debian stable amd64 ( je cree un lien de src/icas vers ton binaire)
et a part le 3 (il faudra que je verifie ce que j'ai fait sous fedora) il y a pas mal d'erreurs communes:
PASS: chk_integrate
PASS: chk_factor
PASS: chk_normalize
PASS: chk_partfrac
PASS: chk_limit
267c267
< GF(7,a^7-2*a^6+a^5+a^4-2*a^3+2*a^2-a+2,[a,G],undef),
> GF(7,a^7-a^5+a^4+a^3+2*a^2+2*a-3,[a,G],undef),
269c269
< (x+G(a^6+2*a^5+2*a^3+a))*(x+G(a^6+2*a^5+2*a^3+a+1))*(x+G(a^6+2*a^5+2*a^3+a+2))*(x+G(a^6+2*a^5+2*a^3+a+3))*(x+G(a^6+2*a^5+2*a^3+a-1))*(x+G(a^6+2*a^5+2*a^3+a-2))*(x+G(a^6+2*a^5+2*a^3+a-3)),
> (x+G(3*a^6-3*a^4+2*a^3+2*a^2-a))*(x+G(3*a^6-3*a^4+2*a^3+2*a^2-a+1))*(x+G(3*a^6-3*a^4+2*a^3+2*a^2-a+2))*(x+G(3*a^6-3*a^4+2*a^3+2*a^2-a+3))*(x+G(3*a^6-3*a^4+2*a^3+2*a^2-a-1))*(x+G(3*a^6-3*a^4+2*a^3+2*a^2-a-2))*(x+G(3*a^6-3*a^4+2*a^3+2*a^2-a-3)),
FAIL: chk_cas
PASS: chk_geo
PASS: chk_morley_demo
PASS: chk_xavier
PASS: chk_fhan1
49,53c49,53
< [[-0.55736977552213+0.10211329682641*I,-0.10401664783431+0.56775892519195*I,0.48078866512274-0.062298514079394*I,0.082404410892112-0.63595588592298*I,-0.35450669195352+5.9396931817446e-15*I],[0.29636348554109+0.6730229049228*I,-0.68556778266381-0.30188758236725*I,0.086569920524869-0.041469250381618*I,0.054852819498708-0.11450904419225*I,-0.76714698372183-6.0784710598227e-15*I],[-0.17518111176245+0.17971791871399*I,-0.18306778883229+0.17844641761389*I,-0.44686313185593-0.28167222559786*I,0.37257764744568+0.59108140337128*I,-0.70100191232384+1.1379786002408e-15*I],[-0.16725502380951-0.0071685165070325*I,0.0073021347873425+0.17037259055191*I,-0.62301713626835+0.26433226773964*I,-0.34964148222062+0.82408643044774*I,0.53836502317464+2.6506574712926e-15*I],[0.1993869011837-0.08574930102098*I,0.087347633692598-0.20310339326772*I,0.071448199077671+0.25256135949362*I,-0.33407169257136-0.094507017403253*I,-0.64640613170429-1.4779844015322e-15*I]],
< 9.4158342716536+7.2190991477712*I,9.4158342716536-7.2190991477712*I,-10.903529951919+7.6765754559479*I,-10.903529951919-7.6765754559479*I,-0.024608639468909,
< [0.082404410892112-0.63595588592298*I,0.054852819498708-0.11450904419225*I,0.37257764744568+0.59108140337128*I,-0.34964148222062+0.82408643044774*I,-0.33407169257136-0.094507017403253*I],
< [3.9834643826095+7.5667477283767*I,0.28094795777892+1.6696346009692*I,-8.5998925319267-3.5847533618648*I,-2.5138352917289-11.669500298153*I,4.3680509562528-1.5340664607974*I],
< [2.4380497620768e-13+6.785683126509e-13*I,5.3268500721515e-13+1.4397372183339e-12*I,4.8139270347747e-13+1.318056774835e-12*I,-3.7125857943465e-13-1.0196288258157e-12*I,4.4764192352886e-13+1.2163603457793e-12*I]
> [[-0.55736977552213+0.10211329682641*I,-0.10401664783431+0.56775892519195*I,0.48078892056982-0.062296542635289*I,0.082401803194436-0.63595622381171*I,-0.35450669195352+6.6613381477509e-15*I],[0.29636348554109+0.6730229049228*I,-0.68556778266381-0.30188758236725*I,0.086570090566185-0.041468895406773*I,0.05485234996114-0.11450926911181*I,-0.76714698372183-5.7835680689067e-15*I],[-0.17518111176245+0.17971791871399*I,-0.18306778883229+0.17844641761389*I,-0.44686197687299-0.28167405792957*I,0.37258007113455+0.59107987563518*I,-0.70100191232384+1.2073675392799e-15*I],[-0.1672550238095-0.007168516507032*I,0.0073021347873418+0.17037259055191*I,-0.6230182201409+0.26432971309496*I,-0.34963810310327+0.82408786412363*I,0.53836502317464+5.6205040621649e-16*I],[0.1993869011837-0.08574930102098*I,0.087347633692598-0.20310339326772*I,0.071447163465153+0.25256165246033*I,-0.33407208008861-0.094505647562565*I,-0.64640613170429-2.1371793224034e-15*I]],
> 9.4158342716536+7.2190991477712*I,9.4158342716536-7.2190991477712*I,-10.903529951919+7.6765754559479*I,-10.903529951919-7.6765754559479*I,-0.024608639468908,
> [0.082401803194436-0.63595622381171*I,0.05485234996114-0.11450926911181*I,0.37258007113455+0.59107987563518*I,-0.34963810310327+0.82408786412363*I,-0.33407208008861-0.094505647562565*I],
> [3.9834954095476+7.5667313943687*I,0.28095480400793+1.6696334489458*I,-8.5999072309095-3.584718098518*I,-2.5138831417574-11.669489990232*I,4.3680446658733-1.5340843717018*I],
> [6.0573768223549e-13+2.4513724383723e-13*I,1.323829934563e-12+5.1114668053742e-13*I,1.202593580274e-12+4.6185277824407e-13*I,-9.2370555648813e-13-3.6592950891645e-13*I,1.1155520951434e-12+4.3431924723336e-13*I]
FAIL: chk_fhan2
PASS: chk_fhan3
PASS: chk_fhan4
PASS: chk_fhan5
PASS: chk_fhan6
PASS: chk_fhan8
31,32c31,32
< 4.4*(x+0.49999995802767719425726)*(x+0.50000004197233049305708)*(x-0.30901699437494853421122+0.95105651629515245315101*I)*(x-0.30901699437494853421122-0.95105651629515245315101*I)*(x+0.80901699437494469055405+0.58778525229247103432521*I)*(x+0.80901699437494469055405-0.58778525229247103432521*I),
< 4.0*(x+0.50000000000000)*(x+0.50000000000000)*(x+0.80901699437494742410229+0.58778525229247312916871*I)*(x+0.80901699437494742410229-0.58778525229247312916871*I)*(x-0.30901699437494742410229+0.95105651629515357211644*I)*(x-0.30901699437494742410229-0.95105651629515357211644*I),
> 4.4*(x+0.8090169944+0.5877852523*I)*(x+0.8090169944-0.5877852523*I)*(x-0.3090169944+0.9510565163*I)*(x-0.3090169944-0.9510565163*I)*(x+0.5+8.029243785e-08*I)*(x+0.5-8.029243785e-08*I),
> 4.0*(x+0.8090169944+0.5877852523*I)*(x+0.8090169944-0.5877852523*I)*(x-0.3090169944+0.9510565163*I)*(x-0.3090169944-0.9510565163*I)*(x+0.5+1.03841722e-07*I)*(x+0.5-1.03841722e-07*I),
35c35
< 4.0*(x+0.50000000000000)*(x+0.50000000000000)*(x^2-0.61803398874989484820459*x+1.0000000000000000000000)*(x^2+1.6180339887498948482046*x+1.0000000000000000000000),
> 4.0*(x^2-0.6180339887*x+1.0)*(x^2+1.0*x+0.25)*(x^2+1.618033989*x+1.0),
FAIL: chk_fhan0
13c13
< [[2,7,1],[3,2,1],[389,2,1],[733,2,1],[156904374622257604823879982847602392900751802349981470895277241,2,[[2,13,1],[3,3,1],[5,2,1],[7,2,1],[56467,2,1],[6553084925887974620811527,2,[[2,5,1],[19,2,1],[71,2,1],[126823,2,1]]]]]],
> [[2,7,1],[3,2,1],[389,2,1],[733,2,1],[156904374622257604823879982847602392900751802349981470895277241,2,[[2,13,1],[3,3,1],[5,2,1],[7,2,1],[56467,2,1],[6553084925887974620811527,2,[[2,5,1],[19,2,1],[71,2,1],[126823,2,1],[8097977,2,1]]]]]],
30a31
FAIL: chk_fhan11
131c131
< % abs acos acosh apply arg asin asinh atan atanh binomial bitand bitor bitxor break ceil charpoly concat conj content cos cosh default divisors erfc eval exp factor factorial floor frac gcd global hilbert imag isprime kill lcm length local matrix max min next nextprime norm print real round select shift sign simplify sin sinh solve sqrt subst sum tan tanh taylor trace truncate type until valuation vector version write
> abs acos acosh arg asin asinh atan atanh binomial bitand bitor bitxor break ceil charpoly concat conj content cos cosh default divisors erfc eval exp factor factorial floor frac gcd global hilbert imag isprime kill lcm length matrix max min next nextprime norm print real reorder round shift sign simplify sin sinh solve sqrt subst sum tan tanh taylor trace truncate type until valuation vector write
134a135
FAIL: chk_fhan12
PASS: chk_fhan13
PASS: chk_fhan14
PASS: chk_fhan15
23c23
< -1.0*(x-4.1058769265275068249727)*(x-2.7492355511548716734078)*(x-0.66337962311369215962721)*(x+0.53659974432785206013379)*(x+3.9818923564682185978739),
> -1.0*(x-4.105876927)*(x-2.749235551)*(x-0.6633796231)*(x+0.5365997443)*(x+3.981892356),
33c33
< -0.5062528649,-0.3273837129,-0.2487685675,0.6001057333,1,1.231806181,
> -0.5062528649,-0.3273837129,-0.2487685675,0.6001057333,1.0,1.231806181,
43c43
< 1.0*(x-2.6055515455697309998164)*(x-2.6055510053583309924421)*(x^2-8.0*x+16.0)*(x^2+9.21110255092796093729*x+0.212111025509279294495e2),
> 1.0*(x-4.001076042)*(x-3.998923958)*(x+4.604193578)*(x+4.606908973)*(x^2-5.211102551*x+6.788897449),
47c47
< [-4.605551275,2.605551275,4],
> [-4.605551275,2.605551275,4.0],
FAIL: chk_fhan16
PASS: chk_fhan17
PASS: chk_fhan19
48,52c48,52
< [a2*C-b2*B+c2*A,a1*C-b1*B+c1*A,c1*b2-b1*c2+C,c1*a2-a1*c2+B,b1*a2-a1*b2+A],
< 14804039419819626332160000000*C^6-101160936035434113269760000000*C^5*B+133236354778376636989440000000*C^4*B^2+34542758646245794775040000000*C^3*B^3-113497635551950468546560000000*C^2*B^4+7402019709909813166080000000*C*B^5+24673399033032710553600000000*B^6+44412118259458878996480000000*C^5*A-187929055968265812049920000000*C^4*B*A+14392816102602414489600000000*C^3*B^2*A+270173719411708180561920000000*C^2*B^3*A-53870254555454751375360000000*C*B^4*A-87179343250048910622720000000*B^5*A+41533555038938396098560000000*C^4*A^2-43178448307807243468800000000*C^3*B*A^2-213013678318515734446080000000*C^2*B^2*A^2+93347693008307088261120000000*C*B^3*A^2+121310878579077493555200000000*B^4*A^2+6579573075475389480960000000*C^3*A^3+67029400706405530337280000000*C^2*B*A^3-62917167534233411911680000000*C*B^2*A^3-84712003346745639567360000000*B^3*A^3-7402019709909813166080000000*C^2*A^4+17682602640340109230080000000*C*B*A^4+31252972108508100034560000000*B^2*A^4-1644893268868847370240000000*C*A^5-5757126441040965795840000000*B*A^5+411223317217211842560000000*A^6,
< 411223317217211842560000000*(C-5*B+A)*(C-B+A)^2*(2*C-2*B+A)*(3*C+2*B-A)*(6*C+3*B-A),
< 36*C^6-246*C^5*B+108*C^5*A+324*C^4*B^2-457*C^4*B*A+101*C^4*A^2+84*C^3*B^3+35*C^3*B^2*A-105*C^3*B*A^2+16*C^3*A^3-276*C^2*B^4+657*C^2*B^3*A-518*C^2*B^2*A^2+163*C^2*B*A^3-18*C^2*A^4+18*C*B^5-131*C*B^4*A+227*C*B^3*A^2-153*C*B^2*A^3+43*C*B*A^4-4*C*A^5+60*B^6-212*B^5*A+295*B^4*A^2-206*B^3*A^3+76*B^2*A^4-14*B*A^5+A^6,
< (C-5*B+A)*(C-B+A)^2*(2*C-2*B+A)*(3*C+2*B-A)*(6*C+3*B-A),
> [c2*A-b2*B+a2*C,c1*A-b1*B+a1*C,c1*b2-b1*c2+C,c1*a2-a1*c2+B,b1*a2-a1*b2+A],
> 411223317217211842560000000*A^6-5757126441040965795840000000*A^5*B-1644893268868847370240000000*A^5*C+31252972108508100034560000000*A^4*B^2+17682602640340109230080000000*A^4*B*C-7402019709909813166080000000*A^4*C^2-84712003346745639567360000000*A^3*B^3-62917167534233411911680000000*A^3*B^2*C+67029400706405530337280000000*A^3*B*C^2+6579573075475389480960000000*A^3*C^3+121310878579077493555200000000*A^2*B^4+93347693008307088261120000000*A^2*B^3*C-213013678318515734446080000000*A^2*B^2*C^2-43178448307807243468800000000*A^2*B*C^3+41533555038938396098560000000*A^2*C^4-87179343250048910622720000000*A*B^5-53870254555454751375360000000*A*B^4*C+270173719411708180561920000000*A*B^3*C^2+14392816102602414489600000000*A*B^2*C^3-187929055968265812049920000000*A*B*C^4+44412118259458878996480000000*A*C^5+24673399033032710553600000000*B^6+7402019709909813166080000000*B^5*C-113497635551950468546560000000*B^4*C^2+34542758646245794775040000000*B^3*C^3+133236354778376636989440000000*B^2*C^4-101160936035434113269760000000*B*C^5+14804039419819626332160000000*C^6,
> 411223317217211842560000000*(A-5*B+C)*(A-3*B-6*C)*(A-2*B-3*C)*(A-2*B+2*C)*(A-B+C)^2,
> A^6-14*A^5*B-4*A^5*C+76*A^4*B^2+43*A^4*B*C-18*A^4*C^2-206*A^3*B^3-153*A^3*B^2*C+163*A^3*B*C^2+16*A^3*C^3+295*A^2*B^4+227*A^2*B^3*C-518*A^2*B^2*C^2-105*A^2*B*C^3+101*A^2*C^4-212*A*B^5-131*A*B^4*C+657*A*B^3*C^2+35*A*B^2*C^3-457*A*B*C^4+108*A*C^5+60*B^6+18*B^5*C-276*B^4*C^2+84*B^3*C^3+324*B^2*C^4-246*B*C^5+36*C^6,
FAIL: chk_fhan20
PASS: chk_fhan21
PASS: chk_fhan9
PASS: chk_fhan18
PASS: chk_fhan7
7 of 30 tests failed
