Hello,
I am using xcas 1.1.4-16 (c) 2000-14.
I found that the following equation would not simplify:
eq1:=1.2*H*phi=(2*H*nH2O)
eq2:=nH2O=solve(eq1,nH2O)[0]
eq3:=simplify(eq2)
eq4:=simplify(eq3)
eq5:=expand(eq4)
I get nH2O=(0.6*H*phi/H) as a result. The H/H will not cancel. Any suggestions?
Thank you
simplification
Re: simplification
That's related to the inexact floating point number. If you replace 1.2 by 6/5 or use simplify(exact()), then it is simplified.
XcasEngGuy
Re: simplification
Interesting. That works. I am confused by the reason why. H/H is not recognized in this case?
Thank you for the answer. I will definitely be using it.
