Integrate root
nenad.miksa
Integrate root
Message par nenad.miksa » mar. août 25, 2015 3:04 pm
If I integrate expression that contains fraction power, I get weird result:
0>> normal(integrate((1) / (root(3, (x)^(2))), x))
Warning, integration of abs or sign assumes constant sign by intervals (correct if the argument is real):
Check [abs(x)]
3*(x*sign(x))^(1/3)/sign(x)
1>> version()
"giac 1.2.0-19, (c) B. Parisse and R. De Graeve, Institut Fourier, Universite de Grenoble I"
I am confused with this warning and result. Shouldn't result be
(3x) / root(3, x^2)
i.e. without signum function? (Wolfram alpha returns this)
Is there a way to tell integrate to use only real domain and prevent it to output sign(x) in result?
Re: Integrate root
Message par parisse » mer. août 26, 2015 1:47 pm
You can run assume(x>0) if you don't want the sign(x).
nenad.miksa
Re: Integrate root
Message par nenad.miksa » mer. août 26, 2015 2:00 pm
Thanks, you are very helpful.
