[giac-1.2.2-75] chk_fhan16 failed
sagitter
Message par sagitter » ven. juil. 15, 2016 6:54 pm
Hi all,
chk_fhan16
test (giac-1.2.2-75) is failed on Fedora 25; please, take a look:
// C
// /usr/share/locale/
// giac
// UTF-8
// Maximum number of parallel threads 4
Help file aide_cas not found
// Unable to find keyword file doc/en/keywords
Help file doc/en/aide_cas not found
Added 0 synonyms
// Warning: q,x, declared as global variable(s). If symbolic variables are required, declare them as local and run purge
// Warning: S3h,x, declared as global variable(s). If symbolic variables are required, declare them as local and run purge
// Warning: S4h,x, declared as global variable(s). If symbolic variables are required, declare them as local and run purge
// Time 0
// Time 0
// Time 0
// Time 0
// Time 0
// Time 0
// Time 0
// Time 0
Near [0,2], 1/epsilon^2*f([0,2]+epsilon*[1,t])=1 roots []
Singular points directions: [cell_i, cell_j, singularity, next solution] [[50,70,2.0*i,-0.00112947877252+2.03333333333*i],[50,70,2.0*i,0.00112947877252+2.03333333333*i],[50,70,2.0*i,-0.00109243590672+1.96666666667*i],[50,70,2.0*i,0.00109243590672+1.96666666667*i],[50,70,2.0*i,-0.00112947877252+2.03333333333*i],[50,70,2.0*i,0.00112947877252+2.03333333333*i],[50,70,2.0*i,-0.00109243590672+1.96666666667*i],[50,70,2.0*i,0.00109243590672+1.96666666667*i],[50,70,2.0*i,-0.00112947877252+2.03333333333*i],[50,70,2.0*i,0.00112947877252+2.03333333333*i],[50,70,2.0*i,-0.00109243590672+1.96666666667*i],[50,70,2.0*i,0.00109243590672+1.96666666667*i],[50,70,2.0*i,-0.00112947877252+2.03333333333*i],[50,70,2.0*i,0.00112947877252+2.03333333333*i],[50,70,2.0*i,-0.00109243590672+1.96666666667*i],[50,70,2.0*i,0.00109243590672+1.96666666667*i]]
Warning! Could not loop or reach boundaries
// Time 0.12
// Time 0
// Time 0.01
// Time 0
// Time 0
// Time 0
// Time 0
// Groebner basis computation time 0.006908 Memory 0.022848M
schur row 1 5.00933e-12
Francis algorithm not precise enough for[1.0,-8.26409192534e+36,1.70738038376e+73,8.85244006785e+107]
Near [0,0], 1/epsilon^2*f([0,0]+epsilon*[1,t])=9*t^2 roots [0.0]
Singular points directions: [cell_i, cell_j, singularity, next solution] [[0,0,0.0,0.00666666666667-0.00171924829653*i],[0,0,0.0,0.00666666666667+0.00120989161359*i]]
// Time 0.4
// Time 0
// Time 0
// Time 0
Hyperbola of center (0,0)
// Time 0
// Time 0.14
// Time 0
// Time 0
// Time 0
// Time 0
// Time 0.01
// Time 0
// Time 0
// Time 0
// Time 0
// Time 0
// Time 0
Warning, argument is not an equation, solving -14699.0*t^6+25716.0*t^5+1779.0*t^4-15116.0*t^3-624.0*t^2+2496.0*t+448.0=0
lt-icas: tpp.c:84: __pthread_tpp_change_priority: Assertion `new_prio == -1 || (new_prio >= fifo_min_prio && new_prio <= fifo_max_prio)' failed.
./chk_fhan16: line 3:  5467 Aborted                 (core dumped) ../src/icas TP16-sol.cas > TP16.tst
32a33,88
> -0.5062528649,-0.3273837129,-0.2487685675,0.6001057333,1.0,1.231806181,
> "Done",
> "Done",
> "No such variable x","No such variable y",
> (x-2)^2+y^2-4,
> y^2-(x-3)*(x^2-16),
> "Done",
> "Done",
> pnt(pnt[circle(pnt[group[0,4],0,2*Pi]),1]),[pnt(pnt[group[-3.97752809-1.118420095*I,-3.974479047-1.191394188*I,-3.971232211-1.264360037*I,-3.967786625-1.337317064*I,-3.964141286-1.410264683*I,-3.960295111-1.483202294*I,-3.956246976-1.556129287*I,-3.951995658-1.629045037*I,-3.947539884-1.701948907*I,-3.942878308-1.774840242*I,-3.938009509-1.847718373*I,-3.932932006-1.920582613*I,-3.927644221-1.993432259*I,-3.922144504-2.066266586*I,-3.916431129-2.13908485*I,-3.910502296-2.211886283*I,-3.904356094-2.284670098*I,-3.897990545-2.35743548*I,-3.89140358-2.43018159*I,-3.884593021-2.502907559*I,-3.877556613-2.575612492*I,-3.870291983-2.648295461*I,-3.862796657-2.720955505*I,-3.855068057-2.793591629*I,-3.847103491-2.866202802*I,-3.838900164-2.93878795*I,-3.830455129-3.011345961*I,-3.82176534-3.083875679*I,-3.812827606-3.156375897*I,-3.803638602-3.228845363*I,-3.794194873-3.301282768*I,-3.784492793-3.37368675*I,-3.774528585-3.446055884*I,-3.764298327-3.518388683*I,-3.753797911-3.590683592*I,-3.743023051-3.662938982*I,-3.731969273-3.735153147*I,-3.72063192-3.8073243*I,-3.70900611-3.879450564*I,-3.697086766-3.951529969*I,-3.684868551-4.023560444*I,-3.672345928-4.095539807*I,-3.659513072-4.167465766*I,-3.646363909-4.239335899*I,-3.632892095-4.311147655*I,-3.619090955-4.382898337*I,-3.604953528-4.454585096*I,-3.590472515-4.526204915*I,-3.575640252-4.597754599*I,-3.560448707-4.669230761*I,-3.544889467-4.740629804*I,-3.528953671-4.811947904*I,-3.512632027-4.883180996*I,-3.495914759-4.954324746*I,-3.478791572-5.025374534*I,-3.46125164-5.096325427*I,-3.44328355-5.167172148*I,-3.42487527-5.23790905*I,-3.406014092-5.308530078*I,-3.386686606-5.379028732*I,-3.36687863-5.449398024*I,-3.346575146-5.51963043*I,-3.32576027-5.589717836*I,-3.304417151-5.659651479*I,-3.282527891-5.729421878*I,-3.260073506-5.799018758*I,-3.23703379-5.868430965*I,-3.213387236-5.937646366*I,-3.189110909-6.006651742*I,-3.164180354-6.075432658*I,-3.138569422-6.14397332*I,-3.112250161-6.212256413*I,-3.085192622-6.28026291*I,-3.057364688-6.347971856*I,-3.028731886-6.415360115*I,-2.999257126-6.482402085*I,-2.968900498-6.549069363*I,-2.937618976-6.615330349*I,-2.905366141-6.681149799*I,-2.872091804-6.746488294*I,-2.83774169-6.811301614*I,-2.802257048-6.875540017*I,-2.765574174-6.939147377*I,-2.727624011-7.002060182*I,-2.688331631-7.064206345*I,-2.647615746-7.125503811*I,-2.605388228-7.185858914*I,-2.561553577-7.245164458*I,-2.516008509-7.30329747*I,-2.468641642-7.360116613*I,-2.419333213-7.415459224*I,-2.367955129-7.469137992*I,-2.314371157-7.520937355*I,-2.260830729-7.56857418*I,-2.205242369-7.613822653*I,-2.147550869-7.65639859*I,-2.087723493-7.695991053*I,-2.025758704-7.732266272*I,-1.961695832-7.764875057*I,-1.895624733-7.793464661*I,-1.827693823-7.817695331*I,-1.758114417-7.837260954*I,-1.687159154-7.851911851*I,-1.615153016-7.861476299*I,-1.542456922-7.865876829*I,-1.469445907-7.865137528*I,-1.396485544-7.859380785*I,-1.323910796-7.848814068*I,-1.252010573-7.833710044*I,-1.18101948-7.814383937*I,-1.11111634-7.791172021*I,-1.042427872-7.764413564*I,-0.9750354619-7.734437559*I,-0.9089832249-7.701553888*I,-0.8442860312-7.666048319*I,-0.7809367417-7.628180478*I,-0.7189123071-7.588183786*I,-0.658178675-7.546266551*I,-0.5986945973-7.502613859*I,-0.5404145039-7.457389734*I,-0.4832906176-7.410739387*I,-0.4272744756-7.36279135*I,-0.3723179968-7.313659469*I,-0.3183742102-7.26344476*I,-0.2653977305-7.212236987*I,-0.2133450534-7.160116048*I,-0.1629851825-7.108005404*I,-0.1133980191-7.055092684*I,-0.06455422216-7.001435342*I,-0.01642547279-6.947085271*I,0.03101544615-6.892089443*I,0.07779456636-6.836490456*I,0.1239367605-6.780327028*I,0.169465698-6.723634415*I,0.214403919-6.666444792*I,0.2587728046-6.608787579*I,0.3025926943-6.550689727*I,0.345882871-6.492175974*I,0.388661621-6.433269069*I,0.4309462995-6.373989968*I,0.4727533741-6.314358011*I,0.5140984646-6.254391072*I,0.5549963874-6.194105701*I,0.5954611956-6.133517244*I,0.6355062593-6.072639952*I,0.6751442456-6.011487078*I,0.7143872001-5.950070963*I,0.7532465554-5.888403116*I,0.7917331971-5.826494281*I,0.829857466-5.764354501*I,0.8676291841-5.701993175*I,0.9050577035-5.639419107*I,0.9421519185-5.576640555*I,0.9789203105-5.513665269*I,1.015370929-5.45050053*I,1.051511434-5.387153186*I,1.087349132-5.323629679*I,1.122890964-5.259936078*I,1.158143547-5.1960781*I,1.193113169-5.132061138*I,1.227805799-5.067890277*I,1.262227139-5.003570317*I,1.29638258-4.939105792*I,1.330277257-4.874500981*I,1.363916032-4.809759927*I,1.397303521-4.744886451*I,1.4304441-4.679884161*I,1.463341878-4.614756464*I,1.496000752-4.54950658*I,1.5284244-4.484137547*I,1.56061626-4.418652231*I,1.592579539-4.353053335*I,1.624317264-4.287343403*I,1.655832211-4.22152483*I,1.687126964-4.155599864*I,1.718203883-4.089570615*I,1.749065132-4.023439056*I,1.779712649-3.957207028*I,1.810148139-3.890876244*I,1.840373133-3.824448291*I,1.870388887-3.757924633*I,1.900196471-3.691306612*I,1.929796711-3.62459545*I,1.959190165-3.557792249*I,1.98837718-3.490897993*I,2.017357824-3.423913546*I,2.04613189-3.356839651*I,2.07469889-3.289676931*I,2.103058058-3.222425886*I,2.131208273-3.155086889*I,2.159148116-3.087660186*I,2.18687579-3.02014589*I,2.214389128-2.95254398*I,2.241685543-2.884854292*I,2.268762035-2.817076515*I,2.295615089-2.749210188*I,2.322240736-2.681254689*I,2.348634406-2.613209228*I,2.374790953-2.54507284*I,2.400704573-2.476844374*I,2.426368754-2.408522484*I,2.451776202-2.340105618*I,2.476918762-2.271592004*I,2.501787354-2.202979641*I,2.526371871-2.134266284*I,2.550661074-2.065449432*I,2.57464247-1.996526313*I,2.598302227-1.92749387*I,2.621624976-1.858348753*I,2.644593686-1.789087303*I,2.667189525-1.719705547*I,2.689391615-1.65019919*I,2.711176879-1.58056362*I,2.732519802-1.510793908*I,2.753392239-1.440884832*I,2.773763128-1.370830902*I,2.793598276-1.300626406*I,2.812860136-1.23026548*I,2.831507548-1.159742199*I,2.849495557-1.089050702*I,2.866775283-1.018185358*I,2.883293778-0.9471409737*I,2.898994132-0.8759130528*I,2.91381559-0.804498113*I,2.927693905-0.732894054*I,2.940561904-0.6611005781*I,2.952350392-0.5891196484*I,2.962989229-0.5169559612*I,2.972408854-0.444617401*I,2.980542054-0.3721154292*I,2.987326039-0.2994653546*I,2.992704602-0.2266864249*I,2.996630443-0.1538016882*I,2.999067216-0.08083758835*I,2.999991259-0.007823290388*I,2.999392837+0.06521023504*I,2.997276655+0.1382312963*I,2.993661673+0.2112086373*I,2.988580147+0.2841125527*I,2.982076129+0.3569158582*I,2.974203437+0.4295946358*I,2.96502345+0.5021287102*I,2.954602784+0.5745018539*I,2.943011163+0.6467017475*I,2.930319417+0.7187197452*I,2.916597895+0.790550505*I,2.901915133+0.8621915401*I,2.886336937+0.933642742*I,2.869925627+1.004905911*I,2.852739699+1.075984321*I,2.83483356+1.146882337*I,2.816257483+1.21760508*I,2.797057676+1.288158161*I,2.777276443+1.358547451*I,2.756952348+1.428778915*I,2.736120456+1.498858474*I,2.714812602+1.568791905*I,2.693057641+1.638584776*I,2.670881647+1.708242386*I,2.648308233+1.777769742*I,2.625358686+1.847171536*I,2.60205225+1.916452138*I,2.578406256+1.985615591*I,2.554436362+2.054665623*I,2.530156644+2.12360565*I,2.505579788+2.192438786*I,2.480717224+2.26116786*I,2.455579188+2.329795425*I,2.430174905+2.398323775*I,2.404512622+2.466754954*I,2.378599725+2.535090775*I,2.352442817+2.603332828*I,2.326047745+2.671482495*I,2.299419714+2.739540958*I,2.272563328+2.807509212*I,2.245482614+2.875388076*I,2.218181067+2.943178195*I,2.190661741+3.010880056*I,2.162927223+3.078493992*I,2.134979676+3.146020185*I,2.106820896+3.213458677*I,2.078452317+3.280809371*I,2.049875012+3.348072039*I,2.021089769+3.415246321*I,1.992097038+3.482331733*I,1.962896993+3.549327665*I,1.933489551+3.616233385*I,1.903874335+3.683048042*I,1.874050729+3.749770663*I,1.844017876+3.816400155*I,1.813774669+3.882935305*I,1.783319785+3.949374781*I,1.752651657+4.015717126*I,1.721768499+4.081960761*I,1.690668308+4.148103981*I,1.65934886+4.214144949*I,1.627807706+4.280081699*I,1.596042181+4.345912127*I,1.564049411+4.411633988*I,1.531826287+4.477244892*I,1.49936948+4.542742297*I,1.466675427+4.608123502*I,1.433740342+4.673385644*I,1.400560185+4.738525685*I,1.367130701+4.803540405*I,1.333447337+4.868426396*I,1.299505333+4.933180045*I,1.265299618+4.99779753*I,1.230824854+5.062274802*I,1.196075426+5.126607573*I,1.161045392+5.190791302*I,1.125728521+5.254821177*I,1.090118222+5.318692098*I,1.054207574+5.382398658*I,1.017989294+5.445935118*I,0.9814556847+5.509295386*I,0.9445986659+5.572472991*I,0.907409738+5.635461054*I,0.8698799071+5.698252252*I,0.8319997214+5.760838791*I,0.7937592277+5.82321236*I,0.7551478994+5.885364091*I,0.7161546313+5.947284513*I,0.6767677235+6.008963496*I,0.6369747757+6.070390198*I,0.5967627081+6.131552991*I,0.5561176581+6.192439397*I,0.5150249598+6.253036003*I,0.473469059+6.313328368*I,0.4314334762+6.373300926*I,0.3889006779+6.432936865*I,0.3458520653+6.492218002*I,0.3022678444+6.551124633*I,0.2581269172+6.60963537*I,0.2134068105+6.667726952*I,0.1680835382+6.725374028*I,0.1221314751+6.782548914*I,0.07552320803+6.839221316*I,0.02822936354+6.895358003*I,-0.01978153327+6.950922443*I,-0.06854327304+7.005874375*I,-0.118092186+7.060169319*I,-0.1684673727+7.113758004*I,-0.219710971+7.166585711*I,-0.2718684447+7.218591502*I,-0.3240325624+7.268803696*I,-0.3771092487+7.318024633*I,-0.4311402398+7.366169765*I,-0.4861689698+7.413144516*I,-0.5422402879+7.458843014*I,-0.5994000101+7.503146427*I,-0.6576942474+7.545921374*I,-0.7171684336+7.587017967*I,-0.7778659538+7.626267851*I,-0.8398262534+7.663482199*I,-0.9030822842+7.698449721*I,-0.9676571273+7.730935086*I,-1.033559636+7.760677946*I,-1.100778978+7.787393071*I,-1.169278066+7.810772398*I,-1.238986051+7.830489568*I,-1.309790403+7.846208101*I,-1.381529544+7.857593827*I,-1.453987553+7.864331871*I,-1.526892879+7.866147694*I,-1.599923017+7.862830181*I,-1.672716436+7.854253282*I,-1.744891507+7.840392043*I,-1.816070148+7.821329141*I,-1.885902247+7.797249689*I,-1.954086362+7.768425412*I,-2.020383343+7.735191362*I,-2.084621534+7.697920148*I,-2.146694434+7.656997744*I,-2.206553033+7.612804082*I,-2.264195366+7.565699154*I,-2.319655484+7.516014711*I,-2.372993247+7.464050241*I,-2.422462491+7.412059782*I,-2.470228818+7.358271431*I,-2.516347633+7.302877452*I,-2.560881244+7.246048151*I,-2.603895556+7.18793381*I,-2.645457696+7.128666773*I,-2.685634339+7.068363485*I,-2.724490575+7.007126421*I,-2.762089156+6.945045841*I,-2.798490075+6.882201352*I,-2.83375028+6.818663294*I,-2.86792364+6.754493947*I,-2.901060862+6.689748576*I,-2.933209645+6.624476338*I,-2.964414732+6.558721066*I,-2.994718075+6.492521941*I,-3.024158976+6.425914071*I,-3.052774262+6.358928997*I,-3.080598417+6.291595118*I,-3.107663763+6.223938072*I,-3.134000599+6.155981052*I,-3.159637332+6.087745092*I,-3.184600633+6.019249309*I,-3.208915541+5.950511114*I,-3.232605596+5.8815464*I,-3.255692933+5.812369699*I,-3.278198377+5.742994331*I,-3.30014157+5.673432525*I,-3.321541007+5.603695526*I,-3.342414155+5.5337937*I,-3.362777507+5.463736611*I,-3.382646641+5.393533106*I,-3.402036304+5.323191374*I,-3.420960449+5.252719011*I,-3.439432298+5.182123075*I,-3.457464391+5.11141013*I,-3.475068597+5.040586292*I,-3.492256233+4.969657265*I,-3.509037998+4.898628379*I,-3.525424111+4.827504617*I,-3.541424257+4.756290648*I,-3.557047666+4.684990849*I,-3.572303151+4.613609329*I,-3.587199071+4.542149948*I,-3.601743428+4.470616342*I,-3.615943835+4.399011932*I,-3.629807584+4.327339945*I,-3.643341613+4.25560343*I,-3.656552553+4.183805263*I,-3.669446765+4.111948168*I,-3.682030299+4.040034724*I,-3.69430897+3.968067373*I,-3.706288322+3.896048433*I,-3.717973667+3.823980105*I,-3.729370104+3.751864481*I,-3.740482507+3.679703549*I,-3.751315531+3.607499205*I,-3.761873659+3.535253252*I,-3.772161178+3.462967412*I,-3.782182204+3.390643328*I,-3.791940659+3.318282569*I,-3.801440344+3.245886638*I,-3.810684873+3.173456969*I,-3.819677708+3.100994939*I,-3.828422207+3.028501866*I,-3.836921538+2.955979015*I,-3.845178786+2.8834276*I,-3.853196889+2.810848788*I,-3.860978644+2.738243701*I,-3.868526773+2.66561342*I,-3.875843865+2.592958985*I,-3.882932391+2.520281398*I,-3.889794723+2.447581628*I,-3.896433156+2.374860608*I,-3.902849853+2.302119242*I,-3.909046906+2.229358404*I,-3.915026306+2.156578938*I,-3.920789954+2.083781665*I,-3.92633968+2.010967378*I,-3.931677225+1.93813685*I,-3.936804235+1.865290828*I,-3.941722287+1.792430041*I,-3.946432892+1.719555199*I,-3.95093748+1.646666991*I,-3.955237405+1.573766091*I,-3.959333946+1.500853155*I,-3.963228331+1.427928825*I,-3.96692171+1.354993729*I,-3.970415151+1.28204848*I,-3.973709698+1.209093679*I,-3.97680629+1.136129917*I,-3.979705827+1.063157772*I,-3.982409141+0.9901778126*I,-3.984917003+0.9171905989*I,-3.98723014+0.8441966814*I,-3.989349206+0.7711966029*I,-3.991274787+0.6981908992*I,-3.993007446+0.6251800994*I,-3.994547649+0.5521647265*I,-3.995895846+0.4791452986*I,-3.997052401+0.4061223288*I,-3.998017637+0.3330963264*I,-3.998791835+0.2600677969*I,-3.999375201+0.1870372432*I,-3.999767891+0.1140051658*I,-3.999970022+0.04097206341*I,-3.999981641-0.03206156626*I,-3.999802753-0.1050952262*I,-3.999433315-0.1781284196*I,-3.998873198-0.2511606487*I,-3.998122272-0.324191415*I,-3.997180301-0.3972202182*I,-3.996047029-0.4702465557*I,-3.994722148-0.5432699222*I,-3.993205261-0.616289809*I,-3.991495957-0.6893057031*I,-3.989593739-0.7623170874*I,-3.987498077-0.8353234391*I,-3.985208362-0.9083242298*I,-3.98272395-0.9813189245*I,-3.980044126-1.054306981*I,-3.977168113-1.12728785*I,-3.97752809-1.118420095*I],4]),pnt(pnt[group[6.131579124-8.22377074*I,6.112259656-8.153342204*I,6.092916033-8.082920309*I,6.073548205-8.012505075*I,6.054156158-7.942096519*I,6.034739858-7.871694656*I,6.015299272-7.801299502*I,5.995834388-7.730911072*I,5.976345183-7.66052938*I,5.956831644-7.590154437*I,5.937293763-7.519786255*I,5.917731528-7.449424845*I,5.89814495-7.379070214*I,5.878534017-7.308722369*I,5.858898749-7.238381318*I,5.839239156-7.168047064*I,5.819555261-7.097719609*I,5.799847084-7.027398954*I,5.780114663-6.957085098*I,5.760358031-6.886778039*I,5.740577248-6.816477769*I,5.720772357-6.746184283*I,5.700943423-6.675897569*I,5.681090524-6.605617616*I,5.661213736-6.535344407*I,5.641313146-6.465077924*I,5.621388851-6.394818146*I,5.601440969-6.324565049*I,5.581469629-6.254318603*I,5.561474948-6.184078777*I,5.541457097-6.113845535*I,5.521416212-6.043618836*I,5.501352495-5.973398636*I,5.48126612-5.903184886*I,5.461157297-5.83297753*I,5.441026261-5.762776509*I,5.420873252-5.692581757*I,5.400698534-5.622393202*I,5.380502399-5.552210765*I,5.36028514-5.482034361*I,5.340047103-5.411863897*I,5.319788643-5.341699272*I,5.299510142-5.271540376*I,5.279212014-5.201387091*I,5.258894702-5.13123929*I,5.238558678-5.061096833*I,5.218204474-4.99095957*I,5.197832618-4.920827342*I,5.177443717-4.850699974*I,5.1570384-4.780577278*I,5.136617342-4.710459052*I,5.11618128-4.640345081*I,5.095730994-4.570235129*I,5.07526731-4.500128945*I,5.054791148-4.430026259*I,5.034303464-4.359926779*I,5.013805294-4.289830194*I,4.993297746-4.219736165*I,4.972782019-4.149644333*I,4.952259381-4.079554306*I,4.931731227-4.009465669*I,4.911199023-3.93937797*I,4.890664361-3.869290727*I,4.870128935-3.799203419*I,4.849594595-3.729115486*I,4.829063318-3.659026328*I,4.808537213-3.588935296*I,4.788018585-3.518841692*I,4.767509902-3.448744766*I,4.747013823-3.37864371*I,4.72653322-3.308537651*I,4.706071198-3.238425652*I,4.685631111-3.1683067*I,4.665216576-3.098179704*I,4.644831522-3.028043488*I,4.624480201-2.957896779*I,4.604167222-2.887738209*I,4.583897571-2.817566295*I,4.563676682-2.747379441*I,4.54351044-2.67717592*I,4.523405274-2.606953866*I,4.503368158-2.536711263*I,4.483406709-2.466445933*I,4.463529213-2.396155524*I,4.443744745-2.325837491*I,4.4240632-2.25548909*I,4.404495404-2.185107354*I,4.385053221-2.114689083*I,4.365749636-2.044230827*I,4.346598909-1.97372887*I,4.327616641-1.903179216*I,4.308820024-1.832577573*I,4.290227895-1.761919347*I,4.271860982-1.691199628*I,4.253742053-1.620413192*I,4.235896163-1.549554506*I,4.2183508-1.478617737*I,4.201136204-1.407596787*I,4.184285517-1.336485328*I,4.167835053-1.265276872*I,4.151824531-1.193964861*I,4.13629724-1.122542787*I,4.121300209-1.051004352*I,4.106884325-0.9793436727*I,4.093104285-0.907555528*I,4.080018496-0.8356356595*I,4.067688762-0.7635811164*I,4.056179775-0.6913906403*I,4.045577314-0.6192001641*I,4.035926191-0.546874845*I,4.02729346-0.4744180007*I,4.019744462-0.4018357938*I,4.01334091-0.3291375103*I,4.008138914-0.2563357077*I,4.004186829-0.183446185*I,4.001523334-0.110487738*I,4.000175574-0.03748168567*I,4.000157936+0.03554881858*I,4.001471258+0.1085796445*I,4.004102771+0.181586637*I,4.008026695+0.2545465721*I,4.013205485+0.3274380242*I,4.019591468+0.4002420684*I,4.027128893+0.4729427698*I,4.035756004+0.5455274414*I,4.045407202+0.6179866845*I,4.056014875+0.6903142474*I,4.067511136+0.7625067478*I,4.07982912+0.8345633112*I,4.092904112+0.9064851679*I,4.106674248+0.9782752463*I,4.121081076+1.049937788*I,4.136069823+1.121478002*I,4.151589577+1.192901764*I,4.167593226+1.264215367*I,4.184037435+1.335425317*I,4.20088244+1.406538173*I,4.218091868+1.477560425*I,4.235632523+1.548498402*I,4.253474154+1.619358208*I,4.271589199+1.690145679*I,4.289952592+1.760866353*I,4.308541524+1.831525459*I,4.327335244+1.902127909*I,4.346314861+1.972678306*I,4.365463211+2.043180943*I,4.384764616+2.113639822*I,4.404204832+2.184058663*I,4.423770847+2.254440919*I,4.443450779+2.324789795*I,4.463233796+2.395108259*I,4.48310997+2.46539906*I,4.503070234+2.535664746*I,4.523106279+2.605907671*I,4.543210488+2.676130016*I,4.56337586+2.7463338*I,4.583595983+2.816520889*I,4.603864948+2.886693013*I,4.624177321+2.956851771*I,4.644528112+3.026998646*I,4.664912687+3.097135009*I,4.685326815+3.167262134*I,4.705766544+3.237381197*I,4.726228273+3.307493292*I,4.746708614+3.377599432*I,4.767204486+3.447700556*I,4.787713006+3.517797537*I,4.808231502+3.587891185*I,4.828757512+3.657982251*I,4.849288727+3.728071432*I,4.869823038+3.798159378*I,4.890358455+3.868246691*I,4.910893145+3.938333932*I,4.931425401+4.00842162*I,4.951953632+4.07851024*I,4.972476351+4.148600242*I,4.99299219+4.218692045*I,5.013499867+4.288786038*I,5.033998194+4.358882583*I,5.054486041+4.428982017*I,5.074962384+4.499084654*I,5.095426253+4.569190783*I,5.115876755+4.639300677*I,5.136313037+4.709414587*I,5.156734319+4.779532747*I,5.177139877+4.849655375*I,5.197529032+4.919782673*I,5.217901141+4.989914827*I,5.238255616+5.060052013*I,5.258591902+5.130194392*I,5.278909501+5.200342113*I,5.299207915+5.270495315*I,5.319486716+5.340654126*I,5.339745484+5.410818665*I,5.359983824+5.480989042*I,5.380201393+5.551165356*I,5.400397851+5.621347703*I,5.420572887+5.691536166*I,5.44072622+5.761730825*I,5.460857583+5.831931753*I,5.480966737+5.902139013*I,5.501053446+5.972352668*I,5.521117509+6.042572772*I,5.541158726+6.112799373*I,5.561176928+6.183032518*I,5.581171955+6.253272245*I,5.601143642+6.323518592*I,5.621091874+6.393771591*I,5.64101652+6.464031269*I,5.660917463+6.534297651*I,5.680794614+6.60457076*I,5.700647869+6.674850613*I,5.72047716+6.745137226*I,5.74028241+6.815430611*I,5.760063551+6.885730779*I,5.779820543+6.956037738*I,5.799553316+7.026351492*I,5.819261854+7.096672046*I,5.83894612+7.166999399*I,5.858606075+7.237333552*I,5.878241705+7.307674502*I,5.897853001+7.378022245*I,5.917439942+7.448376776*I,5.937002539+7.518738085*I,5.956540783+7.589106166*I,5.976054685+7.659481008*I,5.995544252+7.7298626*I,6.015009498+7.80025093*I,6.034450446+7.870645983*I,6.053867108+7.941047747*I,6.073259516+8.011456204*I,6.092627697+8.081871338*I,6.111971689+8.152293133*I,6.131291517+8.222721571*I],4])],
> x^6-4*x^5-36*x^4+176*x^3+208*x^2-1920*x+2304,
> 1.0*(-3.9999999999999494725166+x)*(-3.9999999999999494725166+x)*(x-2.605551275)*(x-2.605551275)*(x+4.605551275)*(x+4.605551275),
> (x-4)^2*(x^2+2*x-12)^2,
> (x-4)^2*(x-sqrt(13)+1)^2*(x+sqrt(13)+1)^2,
> x^3-2*x^2-20*x+48,
> [-4.605551275,2.605551275,4.0],
> "Done",
> [-sqrt(13)-1,sqrt(13)-1,4],
> y^2+6*sqrt(13)+18,y^2-6*sqrt(13)+18,y^2,
> sqrt(6)*I*sqrt(sqrt(13)+3),-sqrt(6)*I*sqrt(sqrt(13)+3),-sqrt(6)*sqrt(sqrt(13)-3),sqrt(6)*sqrt(sqrt(13)-3),0,
> "No such variable u",
> x^2+1/4*y^2+1/9*z^2-1,
> x^2+y^2+z^2-u,
> (729*x^4-270*x^2*z^2+486*x^2*u-1944*x^2+25*z^4-90*z^2*u+360*z^2+81*u^2-648*u+1296)/1296,
> (9*u-5*z^2+27*x^2-36)^2/1296,
> 27*x^2-5*z^2+9*u-36,
> 9*u*(x[3])^2-5*z^2*(x[3])^2+27*(x[1])^2-36*(x[3])^2,
> matrix[[54,0,0],[0,0,0],[0,0,18*u-10*z^2-72]],
> "Done",
> "No such variable t",
> 3,
> [5+(x-5)*t,5+(y-5)*t,10-10*t],
> (14462809*x^4-10268100*x^3*y+5476320*x^3+9453704*x^2*y^2+206460*x^2*y-33894150*x^2-448200*x*y^3-1130040*x*y^2+4617900*x*y+1188000*x+27556*y^4+29880*y^3+154200*y^2-148500*y+680625)/1296,
> "Done",
> 7*x^2+4*x*y+4*x*z+5*y^2+12*y*z+6*z^2+1,
> -x^2-2*x*y-2*x*z-4*y^2-6*y*z-3*z^2-2,
> 7*(x[1])^2+4*x[1]*x[2]+4*x[1]*x[3]+5*(x[2])^2+12*x[2]*x[3]+6*(x[3])^2+(x[4])^2,
> -(x[1])^2-2*x[1]*x[2]-2*x[1]*x[3]-4*(x[2])^2-6*x[2]*x[3]-3*(x[3])^2-2*(x[4])^2,
> matrix[[14,4,4,0],[4,10,12,0],[4,12,12,0],[0,0,0,2]],
> matrix[[-2,-2,-2,0],[-2,-8,-6,0],[-2,-6,-6,0],[0,0,0,-4]],
> -16*(l1-2*l2)*(l1+l2)*(2*l1-l2)*(19*l1-2*l2),
> [[0,1,-1,0]],
> [[0,0,0,-1]],
> [[0,0,-1,0]],
> [[3,0,-1,0]],
> [x,y+t,-t],
> 64*x^4+96*x^3*y+180*x^2*y^2+48*x^2+108*x*y^3+36*x*y+81*y^4+54*y^2+9,
> (8*x^2+6*x*y+9*y^2+3)^2,
> t^2*(x^2+y^2-1)+t*(x*y+y^2-x^2)+x^2+2*y^2-1,
> 2*t*(x^2+y^2-1)+x*y+y^2-x^2,
> 3*x^6+2*x^5*y+16*x^4*y^2-11*x^4-2*x^3*y+20*x^2*y^4-33*x^2*y^2+12*x^2-2*x*y^5+2*x*y^3+7*y^6-19*y^4+16*y^2-4,
> (x^2+y^2-1)*(3*x^4+2*x^3*y+13*x^2*y^2-8*x^2-2*x*y^3+7*y^4-12*y^2+4),
> 3*x^4+2*x^3*y+13*x^2*y^2-8*x^2-2*x*y^3+7*y^4-12*y^2+4,
>  (t)->t^2*(x^2+y^2-1)+t*(x*y+y^2-x^2)+x^2+2*y^2-1,
>  (t)->2*t*(x^2+y^2-1)+x*y+y^2-x^2,
> "Done"
FAIL: chk_fhan16
Full log of build: https://kojipkgs.fedoraproject.org//wor ... /build.log
Re: [giac-1.2.2-75] chk_fhan16 failed
Message par parisse » sam. juil. 16, 2016 7:14 am
Could you run it again? I have no idea why, but sometimes one of the test fails and when you run it again it works.
sagitter
Message par sagitter » sam. juil. 16, 2016 9:20 am
You're right, it passed with a new attempt.
But always fails on Fedora 23 ARM: see at the bottom of https://kojipkgs.fedoraproject.org//wor ... /build.log
Message par parisse » sam. juil. 16, 2016 10:26 am
It's not a failure, just a different ordering. I'll have a look if I can make the ordering more deterministic.
