program, reserved word
Message par compsystems » mer. juil. 12, 2017 1:04 pm
Hello Bernard, I can not find information about the PROGRAM reserved word
For a function of a single variable the definition of a function with program(...) works well, for the n variables, which is the syntax?, see line #17
1:
F1(X):=X^2=9
(X)->X^2=9
2:
F1(3)
9=9
3:
part(F1,0)
"program"
4:
part(F1,1)
X (copy -> paste)
seq[X]
5:
part(F1,2)
0 (copy -> paste)
seq[0]
6:
part(F1,3)
X^2=9
7:
F11:=program(seq[X],seq[0],X^2=9)
(X)->X^2=9
8:
F11(3)
9=9
9:
F11:=program(X,0,X^2=9)
(X)->X^2=9
10:
F11(3)
9=9
11:
V1(X,Y):=2*X^2-Y^2=7
(X,Y)->2*X^2-Y^2=7
12:
V1(2,1)
7=7
13:
part(V1,0)
program (copy -> paste)
"program"
14:
part(V1,1)
(X,Y) (copy -> paste)
X,Y
15:
part(V1,2)
(0,0) (copy -> paste)
0,0
16: part(V1,3)
2*X^2-Y^2=7
17:
V11:=program((X,Y), (0,0), 2*X^2-Y^2=7)
V11:=program(seq[X,Y], seq[0,0], 2*X^2-Y^2=7)
 (X)->2*X^2-Y^2=7  // does not define the variable Y
18:
V11(2,1)
error
Re: program, reserved word
Message par parisse » jeu. juil. 13, 2017 6:02 am
program should not be used directly by the user, it's much safer and simpler to use the normal syntax to build a program. There are 3 arguments, the variables (in a list), the values (in a list) and the list of instructions,
Message par compsystems » jeu. juil. 13, 2017 12:22 pm
ok, The use of lists as arguments works well,
17
V1:=program(list[X,Y],list[0,0],2*X^2-Y^2=7)
 (list[X,Y])->2*X^2-Y^2=7
18
V1(2,1)
7=7
or
17
V1:=program([X,Y],[0,0],2*X^2-Y^2=7)
([X,Y])->2*X^2-Y^2=7
18
V1(2,1)
7=7
BP, can please improve the following results that PART cmd performs (Output between parentheses to output in square brackets), so that the reverse process is correct
(X,Y) => [X,Y] => (copy -> paste) list[X,Y]
part(V1,1) => [X,Y]
1:
(X,Y)->2*X^2-Y^2=7
2:
part(V1, 0)
"program"
3:
part(V1, 1)
(X,Y)   => [X,Y] (copy -> paste)
list[X,Y]
4:
part(V1, 2)
[0,0] (copy -> paste)
list[0,0]
Message par parisse » jeu. juil. 13, 2017 4:37 pm
I don't understand what do you want to do.
By the way, there is nothing special about list[ vs [
Message par compsystems » lun. juil. 17, 2017 5:01 pm
The output of the PART command for the following case, must return a list [x,y] and not (x,y), so that the reverse process can be rebuilt.
1:
V9(X,Y):=2*X^2-Y^2=7
[X,Y]->2*X^2-Y^2=7
2:
[ part(V9,1), part(V9,2), part(V9,3) )
[X,Y,0,0,2*X^2-Y^2=7]  =( 5 args
[ [X,Y],[0,0],2*X^2-Y^2=7]  =) 3 args OK
Message par parisse » lun. juil. 17, 2017 6:39 pm
It's because sequences are concatenated during evaluation. But you can convert yourself sequences to lists by adding [], like for example [part(V9,1)]
