print
belanger
print
Message par belanger » mer. mars 07, 2018 11:01 pm
The (French) manual (in the section on printpow) indicates that given an expression like 2^3,
the print command will print 2^3 formatted in one of three ways, but then return the value 8.
In the current version of Xcas, the print command will print the evaluated expression, 8, and
return the value 1. Which one is the intended behavior?
(I sometimes come up with what look like minor bugs, which either disappear when the next update comes out, or are either very minor or probably due to user error. I could try to put them in the bugs subforum or this one. Is there a preference?)
Jay
Re: print
Message par parisse » jeu. mars 08, 2018 7:20 am
2 should be replaced by x.
You can post in both sections, that's not important, I read both :-)
