flag to deactivate (=) => (==)
Message par compsystems » sam. juil. 28, 2018 4:09 am
Hello, Bernard, some procedures in the hp-prime do not return the desired, due to the problem of pre-assigning variables to zero value
example
X, Y RETURNS 0,0
V1(X,Y):=X-2*Y=7; V2(X,Y):=5*X-3*Y=2; returns [0,0]
  0-2*0=7, 5*0-3*0=2
  0=7, 0=2
  0/FALSE, 0/FALSE
A possible solution is that the operator (=) does not act as a comparison operator, this could be done using a flag to deactivate it.
EXPORT plotGraphParHome()
BEGIN
	LOCAL Symbolic_sview:=0;
	LOCAL Plot_sview:=1;
	LOCAL Numeric_sview:=2;
	LOCAL SymbolicSetup_sview:=3;
	LOCAL PlotSetup_sview:=4;
	LOCAL NumericSetup_sview:=5;
	STARTAPP("Parametric");
	Parametric.X1:='T^2';
	Parametric.Y1:='T';
	Parametric.CHECK(1);
	STARTVIEW(Plot_sview);
	RETURN "Done";
END;
#cas
	plotGraphParCAS():=
	BEGIN
		PURGE(T);
		X1(T):=T^2;
		Y1(T):=T;
		CHECK(1);
		RETURN "Done";
	END;
#end
EXPORT plotAdvGraphHOME()
BEGIN
	STARTAPP("Advanced Graphing");
	V1:='X-2*Y=7';
	V2:='5*X-3*Y=2';
	CHECK(1);CHECK(2);
	RETURN "Done";
END;
#cas
	plotAdvGraphCAS():=
	BEGIN
		PURGE(X,Y);
		V1(X,Y):=X-2*Y=7;
		V2(X,Y):=5*X-3*Y=2;
		CHECK(1);CHECK(2);
		RETURN "Done";
	END;
#end
Re: flag to deactivate (=) => (==)
Message par parisse » sam. juil. 28, 2018 5:53 pm
Don't use HP reserved variables...
Message par compsystems » ven. août 03, 2018 9:40 pm
Hello, if the code requires graphing, the only way is to use the reserved variables. Adding this flag avoids many problems, and warning messages. I think it's very important to add this flag
Message par parisse » dim. août 05, 2018 7:53 pm
Why? You can use Giac native plot instructions like plotfunc, plotparam, etc.
Message par compsystems » sam. sept. 01, 2018 11:17 am
Hello, BP, I refer to xcas on the hp-prime, also using xcas-pc
I ask the student to enter expressions on the worksheet and sometimes to made comparison of expressions. By means of a flag we expand in the power of manipulation and interpretation.
