Error with list2expr
Message par compsystems » mar. août 07, 2018 7:36 pm
Hello BP, in the last version I observe
1: linsolve([x+y=(1+√2)/2, x-y=(1-√2)/2],[x,y])
[1/2,1/(sqrt(2))]
2: list2exp(ans(-1),[x,y])
error
3: list2exp(linsolve([x+y=(1+√2)/2, x-y=(1-√2)/2],[x,y]),[x,y])
error
4: list2exp([[1/2,1/(sqrt(2))]],[x,y])
(x=1/2) and (y=(1/sqrt(2)))
5: linsolve([x+2*y=5,1/2*x+y=5/2],[x,y])
[-2*y+5,y]
6: list2exp(linsolve([x+2*y=5,1/2*x+y=5/2],[x,y]),[x,y])
error
7: list2exp([[-2*y+5,y]],[x,y])
(x=-2*y+5) and (y=y) =)
Re: Error with list2expr
Message par parisse » mer. août 08, 2018 8:20 pm
Yes, that's because linsolve returns a unique solution instead of a list of solutions. Will be fixed.
Message par compsystems » jeu. août 09, 2018 5:48 pm
I do not know, if it is important to add an extra parameter '=' to get more quickly input and the most 'explicit' form output
1: linsolve( [x+y=(1+√2)/2, x-y=(1-√2)/2], [x, y] )
[ 1/2, 1/(sqrt(2)) ]
2: linsolve( [x+y=(1+√2)/2, x-y=(1-√2)/2], [x, y], '= ' )
[ x=1/2, y=(1/sqrt(2) ]
Message par parisse » jeu. août 09, 2018 8:11 pm
Ok, I will add '=' as an optional arg for linsolve, this is coherent with solve.
Message par compsystems » ven. août 10, 2018 2:19 pm
Thanks Mr Bernard.
and with desolve and similar cmds
desolve(((y')'+y) = 0,y) returns
G_0*cos(x)+G_1*sin(x)
desolve(((y')'+y) = 0,y, '=' )
y(x)=G_0*cos(x)+G_1*sin(x)
Message par compsystems » mar. août 14, 2018 3:12 pm
Hello, the inverse function exp2list, automatically changes to ti68k mode flag, this causes that when the code is re-executed the outputs fail, the exp2list command must not change the flag automatically to ti68k mode.
Message par parisse » jeu. août 16, 2018 8:34 am
I can't reproduce, I tried with the first example of the help.
Message par compsystems » jeu. août 16, 2018 2:05 pm
hello, there's no problem with exp2list, it's with list2exp, with linsolve,
list2exp(linsolve([equal(x+y,(1+√2)/2),equal(x-y,(1-(√2))/2)],[x,y]),[x,y]) // change to ti89 mode
As the list2exp and exp2list commands are new please can rename to list2expr and expr2list, with the purpose of differences the EXPonential function of EXPRession
Thanks
Message par parisse » jeu. août 16, 2018 6:24 pm
Thanks Mr Bernard.
I don't think it's worth the effort. Students running desolve are at a higher level of math, they can certainly understand the current form for the solution (or if they don't, the problem will most probably be with the integration constants).
Message par parisse » jeu. août 16, 2018 6:32 pm
It works with the current devel version.
