case 3,5,9:
case 3,5,9:
Message par compsystems » jeu. sept. 13, 2018 4:49 pm
Hello, is possible that CASE operates with several options?
case 3,5,9:
test_switch():={
	local c;
	assume(c,DOM_INT);
	DispG; ClrIO; ClrGraph;
	input("c",c);
	switch(c){
		case 1:{
			printf("1");
			break;
		case 3:{
			printf("3, 5 o 9");
			break;
		case 7:{
			printf("7");
			break;
		default:{
			printf("not is 1, 3, 5, 7, 9");
			break;
	Pause; DispHome;
	return Done;
Re: case 3,5,9:
Message par parisse » ven. sept. 14, 2018 9:10 am
No...
Re: case 3,5,9:
Message par compsystems » ven. sept. 14, 2018 1:29 pm
the following code why does not it work?
case 3:{nop}
case 5:{nop}
case 9:{...
sin_titulo_05():={
	local c; // definir la varible de consulta
	assume(c,integer);
	DispG; ClrIO; ClrGraph; // inicia la consola entrada/salida, luego limpiar pantalla
	input("c",c);
	switch(c){
		case 1:{
			printf("1");
			break;
		case 3:{nop}
                case 5:{nop}
		case 9:{
			printf("3, 5 o 9");
			break;
		case 7:{
			printf("7");
			break;
		default:{
			printf("no es 1, 3, 5, 7, 9");
			break;
	//Pause; DispHome; // cierra la consola entrada/salida
	return Done;
Re: case 3,5,9:
Message par parisse » ven. sept. 14, 2018 3:05 pm
Xcas case does not follow exactly the same rule as in C, if there is no break in a case then the next case are not taken but the default case is executed. In other words, put a break unless you know exactly what you do.
