High BP
autosimplify(0):;
combine(ln(x)+ln(y),log), combine(ln(x)-ln(y),log)
=> ln(x*y), ln(x/y)
(a^x)*a^y, expand((a^x)*a^y), combine((e^x) * e^y,exp)
=> "a^x*a^y, a^(x+y), exp(x+y)
(a^x)/a^y, expand((a^x)/a^y), combine((e^x)/e^y,exp)
=> a^x/a^y, a^(x-y),exp(x-y)
combine((e^x) * e^y,e), combine((e^x) / e^y,e) =>
"combine(exp(x)*exp(y),exp(1))"
"Error: Bad Argument Value"
error with combine((e^x) * e^y,e)
- Contact :
Re: error with combine((e^x) * e^y,e)
The second argument to combine should be a function (or class of functions). So (I would think) putting a number as the second argument should return an error.
- Contact :
but e==exp(1) returns true
I think, that should accept the expression exp(1) as synonymous with e, just like ln does with log.
e is not the same type as exp, e is a number, exp is a function.
- Contact :
ok, but the CAS could support symbols, which can be very useful in programming
for example
combine( (a^x) * a^y, a) [enter] this would return a^(x+y)
combine( (a^x) / a^y, a) [enter] this would return a^(x-y)
for example
