How to solve this system of equation in Xcas
jocaps
Message par jocaps » jeu. oct. 11, 2018 7:58 am
Hi,
I have a system of equations over Q(rootof(z^3-2)) that if I give in maple I get solutions with different branches and some of them are given as algebraic numbers. The code in maple looks like this:
p1 := 2*RootOf(_Z^3-2)^2*z*x^2+8*RootOf(_Z^3-2)^2*z^2*x+2*x^3*RootOf(_Z^3-2)+8*x^2*RootOf(_Z^3-2)*z-2*w^2*x-14*w^2*z+126*w*x*z+28*x^3-42*x^2*z+3*x*y^2-42*x*y*z-296*x*z^2-294*y*z^2-700*z^3;
p2 := 2*RootOf(_Z^3-2)^2*x^3+22*RootOf(_Z^3-2)^2*z*x^2+56*RootOf(_Z^3-2)^2*z^2*x+6*x^3*RootOf(_Z^3-2)+24*x^2*RootOf(_Z^3-2)*z+2*w^2*z-42*w*x*z-10*x^3+2*x^2*z-x*y^2+28*x*z^2+42*y*z^2+100*z^3;
p3 := 2*w*RootOf(_Z^3-2)^2*x^2+8*x*w*RootOf(_Z^3-2)^2*z+2*y*RootOf(_Z^3-2)*x^2+8*x*y*RootOf(_Z^3-2)*z+42*x^2*z+168*x*z^2;
f := p1^2+p2^2+p3^2;
solve({p1 = 0, p2 = 0, p3 = 0});
Using Xcas, I have this code
r:=rootof(x^3-2);
p1 := 2*r^2*z*x^2+8*r^2*z^2*x+2*x^3*r+8*x^2*r*z-2*w^2*x-14*w^2*z+126*w*x*z+28*x^3-42*x^2*z+3*x*y^2-42*x*y*z-296*x*z^2-294*y*z^2-700*z^3;
p2 := 2*r^2*x^3+22*r^2*z*x^2+56*r^2*z^2*x+6*x^3*r+24*x^2*r*z+2*w^2*z-42*w*x*z-10*x^3+2*x^2*z-x*y^2+28*x*z^2+42*y*z^2+100*z^3;
p3 := 2*w*r^2*x^2+8*x*w*r^2*z+2*y*r*x^2+8*x*y*r*z+42*x^2*z+168*x*z^2;
f := p1^2 + p2^2 + p3^2;
solve([p1,p2,p3])
The output is
Algebraic extensions not allowed in a rootof Error: Bad Argument Value
Am I already encountering a giac limitation? Is there a way to get the solution similar to maple? Maple provides the following solution
Re: How to solve this system of equation in Xcas
Message par parisse » jeu. oct. 11, 2018 12:18 pm
What are your unknowns?
Don't define r as a rootof and solve by adding the equation r^3-2=0 and you will have a polynomial system without algebraic extensions inside. For example:
restart;
Then
solve([p1,p2,p3,r^3-2],list_of_unknowns)
Beware that solve does not necessarily return all the solutions if there are parameters, it depends if it can solve equations after elimination. If there are no parameters, then rational univariate representation is used and you will get all solutions.
By the way, p3 has 3 factors, you will get (fast) answers without defining r if you solve for each factor of p3 (there is currently no factorization check in the solve code).
jocaps
Message par jocaps » ven. oct. 12, 2018 10:32 pm
Hi Bernard,
My unknowns are x,y,z and w. I think the solutions are parametrizable surfaces, so it can be parametrized by at least 2 parameters and not less. So we could assume the unknowns to be say z and w. But here, giac is struggling to find a solution (computation in my laptop does not end).
Edit: I see now what you mean. I should just use gbasis instead and just work on each factors of p3. Is there any advantage of using solve here?
Jose
Message par parisse » sam. oct. 13, 2018 6:23 am
solve will mostly be useful if there is a set of isolated solutions that can be described with the rational univariate representation (all solutions as a list of rational fractions in terms of roots of a single polynomial). Otherwise, gbasis is safer, it will not miss solutions by assuming generic values for parameters.
