new line char equal to (;)
Message par compsystems » mar. févr. 26, 2019 3:10 pm
Hello BP,
Copying the example
se:=(1,2,4,2)
li:=[se]
op(li)
nop(se)
nops(se)
%{se%}
size([se])
size(%{se%})
[enter] error
of 2.7 Listes, séquences, ensembles
https://www-fourier.ujf-grenoble.fr/~pa ... html#sec12
to work on the command entry, you have to add; at the end of each instruction
se:=(1,2,4,2);
li:=[se];
op(li);
nop(se);
nops(se);
%{se%};
size([se]);
size(%{se%});
[enter] ok
but within a program it is not obligatory either (;)
prg():={
	local se, li;
	se:=(1,2,4,2)
	print(se)
	li:=[se]
	print(li)
	print( op(li) )
	print( nop(se) )
	print( nops(se) )
	print( %{se%} )
	print( size([se]) )
	print( size(%{se%}) )
prg()[enter] ok
then Why in the entry line if it is required (;)?, I think that the new line char should be interpreted as end of sentence
on-line session Xcas
Re: new line char equal to (;)
Message par compsystems » mer. févr. 27, 2019 2:26 pm
what I said before is not true, math expressions requires finishing with ( ; ) =(
function area_of_circle( )
begin
	local Area, Radious;
	ClrIO
	printf( "Please enter the radius of a circle" )
	input( Radious )
	Area := 3.14 * Radious ^ 2;
	printf( "The area is %gen", Area )
	return Done
end
ok but without ;
(NULL)->
{ local Area,Radious;
ClrIO ;
printf("Please enter the radius of a circle");
input(Radious);
Area:=3.14*Radious^(2*printf("The area is %gen",Area)); // error =(
return(Done);
Message par parisse » jeu. févr. 28, 2019 6:47 am
Sometimes it's important to have newlines that are not equivalent to ;, like in programming structures.
