definitions with lambda
Message par compsystems » mer. mars 13, 2019 3:35 pm
Hello
Is it possible to define functions with lambda for a block of expressions?, currently only works for an expression
def add_(x, y): return x + y
add_ = lambda x, y : x + y # ok
now
def calculator( oper, a, b ):
    if "addition" == oper:
        return a + b
    elif "subtraction" == oper:
        return a - b
    elif "multiplication" == oper:
        return a * b
    elif "division" == oper:
        return a / b
    else:
        return None
ok
but
calculator =  lambda oper, a, b:
        return a + b
        return a - b
        return a * b
        return a / b
    else:
        return None
error
Re: definitions with lambda
Message par parisse » mer. mars 13, 2019 6:42 pm
lambda is supported if the definition is on 1 line.
