I like the way the new version handles variable names in Latex, separating products of variables with a dot in a very consistant manner, makeing mass*var not end up looking like massvar in the latex output for example. Thank you very much for that.
I have been working with units lately which allows me to generate a full set of equations for computer modeling, taking units into account. In the Latex output, the units often run together, making them hard to read. Also, a small note, the unit for inch in the Phys menu is "inch" in the Length submenu and "in" in the Area and Vol submenus. "_inch" is the unit that works.
I have attached a sample units calculation I did to make a set of equations ready for a Fortran program (yes, I'm old) as an example of what I mean.
Matt
Units in latex
XcasEngGuy
Units in latex
- Pièces jointes
- Sample.zip
- (50 Kio) Téléchargé 1018 fois
Re: Units in latex
Hi Matt,
I see what you mean. In latex, it is recommended to let the typesetter handle implicit multiplication, i.e. to simply separate factors by spaces in the input file; however, this approach does not work well for units.
Rather by resorting to explicit multiplication with \cdot, I fixed the issue by including a small space \, between successive units in the giac->latex conversion routine. This makes units appear lightly separated from each other, which I hope will be enough for high readability.
The fix will appear in one of the subsequent releases.
Luka
Luka
XcasEngGuy
Re: Units in latex
Great. I look forward to that.
Matt
Matt
