when cmd
when cmd
Message par compsystems » jeu. mai 06, 2021 4:07 pm
Hello I have problems defining a function in xcas
function f(testvar):={
   return when( testvar, true, false );
Syntax compatibility mode: xcas
Parse error line 1 column 20 at :=
Re: when cmd
Message par compsystems » ven. mai 07, 2021 2:31 am
this way it works fine.
function f(testvar)
end;
purge(x); f(x); [Enter] returns ((x)? true : false)
and why doesn't it return an error message ""Unable to check test Error: Bad Argument Value"
Re: when cmd
Message par parisse » ven. mai 07, 2021 6:23 am
Your first attempt should be without the keyword function.
when does not error if the test value is unknown, it returns the argument un-evaluated.
Re: when cmd
Message par compsystems » ven. mai 07, 2021 4:24 pm
Hello, in the case of the first post, this is the template that Xcas puts in the installation version for PC
Prg Menu New prg
about When cmd, I think it is very important to define a fourth parameter, that is, if it cannot evaluate to a logical value (firts arg), execute the fourth argument, this is important to define custom output messages or execute a third option T/F another, I think this is how the When command Works in the Texas instrument calculators.
Re: when cmd
Message par parisse » sam. mai 08, 2021 10:26 am
Prg Menu New prg
Indeed, will be fixed.
when already accepts a 4th argument.
Re: when cmd
Message par compsystems » sam. mai 08, 2021 3:17 pm
> but I think, it is not documented yet.
https://www-fourier.ujf-grenoble.fr/~pa ... _default52
Re: when cmd
Message par parisse » sam. mai 08, 2021 6:55 pm
Unfortunately that's the case of many compatibility commands, it would require much work to provide complete documentation...
Re: when cmd
Message par compsystems » lun. mai 10, 2021 3:25 am
Updating documentation takes time, but if these little ones get lost, it will be more difficult
It seems to me that it is important to update this command at least in the French document.
WHEN CMD
4 arguments
1: test to solve
2: action for true
3: action for false
4: optional if you cannot solve the test
with 4 args
PHP Code:
#cas
test_whencmd_cas_0(testvar):=
begin
return when( testvar, true, false, "other" );
end;
#end
