collection of issues found in 1.9-07
Nasser
Message par Nasser » jeu. juin 16, 2022 4:56 am
Please find current collection of issues found. Some of these might be result of same problem or might be fixed in current source.
>giac
// C.UTF-8
// /usr/local/share/locale/
// giac
// UTF-8
// Maximum number of parallel threads 24
Added 0 synonyms
Welcome to giac readline interface, version 1.9.0
(c) 2001,2021 B. Parisse & others
May contain BSD licensed software parts (lapack, atlas, tinymt)
Type ?commandname for help
0>> integrate(1/(e*x+d)^(5/2)/(-c*e^2*x^2+c*d^2)^(1/2),x)
Segmentation fault
0>> integrate((e*x+d)^(9/2)/(-c*e^2*x^2+c*d^2)^(3/2),x)
Segmentation fault
0>> integrate((e*x+d)^(7/2)/(-c*e^2*x^2+c*d^2)^(3/2),x)
Segmentation fault
Segmentation fault
0>> integrate(1/(c*e^2*x^2+2*c*d*e*x+c*d^2)^(3/2),x)
Segmentation fault
0>> integrate(1/(e*x+d)/(c*e^2*x^2+2*c*d*e*x+c*d^2)^(3/2),x)
Unable to build a single algebraic extension for simplifying.
Trying rational simplification only. This might return a wrong answer if simplifying 0/0!
Segmentation fault
0>> integrate((e*x+d)^(3/2)*(c*x^2+b*x+a)^p,x)
giac: poly.h:1965: void giac::Tegcdtoabcuv(const giac::tensor<T>&, const giac::tensor<T>&, const giac::tensor<T>&, giac::tensor<T>&, giac::tensor<T>&, giac::tensor<T>&, giac::tensor<T>&) [with T = giac::gen]: Assertion `temp.coord.empty()' failed.
Aborted
0>> integrate((g*x+f)/(e*x+d)^(5/2)/(-c*e^2*x^2-b*e^2*x-b*d*e+c*d^2)^(1/2),x)
Warning, need to choose a branch for the root of a polynomial with parameters. This might be wrong.
The choice was done assuming [b,c,d,exp(1),exp(2)]=[94,26,-27,20,-27]
The choice was done assuming [b,c,d,exp(1),exp(2)]=[45,-9,71,12,-14]
Segmentation fault
0>> integrate(1/x/(c*x^2+b*x+a)^(3/2)/(f*x^2+e*x+d),x)
Segmentation fault
2>> integrate((D*x^3+C*x^2+B*x+A)/(a*x^4+b*x^3+c*x^2+b*x+a),x)
  what():  Not invertible Error: Bad Argument Value
terminate called recursively
Aborted
0>> integrate(1/(b*x+a)/(d*x^2+c)^(1/2)/(f*x^2+e)^(1/2),x)
Segmentation fault
0>> integrate((c*x^2+b*x+a)^m*(g*x^3+f*x^2+e*x+d)^n*(-a*d+(a*e*n+b*d*m)*x+(2*a*f*n+b*e*m+b*e*n+2*c*d*m+a*f+b*e+c*d)*x^2+(3*a*g*n+b*f*m+2*b*f*n+2*c*e*m+c*e*n+2*a*g+2*b*f+2*c*e)*x^3+(b*g*m+3*b*g*n+2*c*f*m+2*c*f*n+3*b*g+3*c*f)*x^4+c*g*(4+2*m+3*n)*x^5)/x^2,x)
Simplification assuming d near 0
Aborted
0>> integrate((d*i*x+c*i)^3*(A+B*log(e*(b*x+a)/(d*x+c)))/(b*g*x+a*g)^3,x)
Aborted
0>> integrate(x^3*log(c*(a+b/x^2)^p)/(e*x+d),x)
Simplification assuming a near 0
Aborted
0>> integrate(x^3*log(c*(a+b/x^3)^p)/(e*x+d),x)
Aborted
Re: collection of issues found in 1.9-07
Message par parisse » jeu. juin 16, 2022 11:27 am
Hi,
Could you please just send the inputs that raise a bug? (Each line ending with a ;)
Something like
integrate((e*x+d)^(9/2)/(-c*e^2*x^2+c*d^2)^(3/2),x);
integrate(1/(c*e^2*x^2+2*c*d*e*x+c*d^2)^(3/2),x);
This is a lot easier for me, because I can copy/paste the whole input at once in a file and run icas on the file, check if the bugs are already fixed, or run the file from gdb for those that are not yet fixed.
Thanks!
lukamar
Message par lukamar » sam. juin 18, 2022 1:22 pm
It seems that using e as a symbol in the expression e*x+d is the problem. In giac, it is the base of natural logarithm (a predefined constant). Nevertheless, using it shouldn't crash icas.
Message par parisse » sam. juin 18, 2022 6:44 pm
parse_e(1) will prevent parsing e to exp(1). From C++ parse_e(true,&ct);
Message par parisse » dim. juin 19, 2022 6:07 am
https://www-fourier.univ-grenoble-alpes ... .0.tar.bz2 was updated with fixes. Some integrals still hang, but they should not segfault anymore...
