using assume can cause crash during eval
lukamar
Message par lukamar » sam. nov. 12, 2022 11:38 am
If you enter
assume(a<b)
and then
assume(b<a)
then trying to compute with a and b, e.g.causes an infinite loop, crashing after a while (stack overflow?).
Re: using assume can cause crash during eval
Message par parisse » mar. nov. 15, 2022 8:41 am
I don't get a crash here (linux 64 bits), after 35 seconds I get a+b. Probably a stack overflow indeed, I should probably add a stack protection like MicroPython does, with a max stack size that is initialized at the begin of main() and a stack check at every evaluation.
Message par parisse » mar. nov. 15, 2022 9:37 am
I tried to add a stack check, with a limit less than 100K of stack one gets a stack overflow on your example. But then some regression tests fail (chk_limit). Therefore I will not enable this, at least not for Linux.
lukamar
Message par lukamar » mar. nov. 15, 2022 3:08 pm
Thanks for clearing this up. My example is quite pathological, but maybe assume should report a warning when conflicting assumptions from the user are detected.
Message par parisse » mer. nov. 16, 2022 6:11 am
Indeed, I plan to add a check for "recursive" assumptions, like for :=
