Differentiating vectors of functions
alexg
Message par alexg » mar. janv. 25, 2011 5:56 pm
Just another little thing I noticed, not very important but I think worth mentioning:
As far as I can tell, giac's function_diff() is pretty much the same as Maple's D(), which giac also supports.
Yet, function_diff([sin,cos,tan]) correctly gives
 (` x`)->{
  cos(` x`);
  -(sin(` x`));
  1+tan(` x`)^2;
While D([sin,cos,tan]) gives
D(['sin','cos','tan'])
Could that be improved?
Re: Differentiating vectors of functions
Message par parisse » mar. janv. 25, 2011 8:14 pm
You must select maple mode if you want D to be a synonym for function_diff, otherwise it is a valid identifier name (especially useful for geometry).
alexg
Message par alexg » mar. janv. 25, 2011 8:37 pm
Thanks very much for that, I was getting a bit confused with the Maple-mode support...
I now see it's working OK, even if the answer is the slightly different
expr("proc(` x`)
  cos(` x`);
  -(sin(` x`));
  1+tan(` x`)^2;
end;")
Gives me enough to go on, anyway
Dernière modification par alexg le mer. janv. 26, 2011 2:47 pm, modifié 1 fois.
Message par parisse » mer. janv. 26, 2011 6:39 am
Indeed, display should be optimized. I don't have much time for that now since it's not critical...
