graph theory commands for Giac
Re:
The debian 9 binaries should be updated, graph(1) does not segfault anymore.
						Re:
Thank you Jose, the implementation of checking graph isomorphism is planned but not yet implemented, I haven't tackled the problem yet at all, so I'll appreciate any idea of how to do it best. I know it's a difficult problem. In the worst case the algorithm will be a naive one (with a high complexity), based on checking graph invariants, if all known algorithms are too complex.
					Dernière modification par lukamar le ven. mai 25, 2018 5:57 am, modifié 1 fois.
						Re:
I've written short help for the commands, they're located in the "doc" directory. It is meant to be appended to the "aide_cas" file. Also, I've mirrored all changes made before inclusion to the Giac source so that changing the headers every time is not needed. I've also fixed a couple of bugs affecting some commands.
There are however some issues in the latest Xcas binaries.
1. Firefox interface prints the string created by the "is_graphe" function and displays it properly, but Xcas displays the gen structure as if the "is_graphe" hasn't been called at all.
2. The enum move_to_dispatch_h in "dispatch.h" may be removed, and its elements included at the end of maple_conversion enum:How to make these numbers assigned to keywords "connected", "spring", "tree" etc. in Xcas? These are the options for some commands.
3. When displaying graph drawings, edges are not displayed, only vertices and labels are. However when outputted to cout and copied in Xcas, everything works. Edges are created by adding symbolic(at_segment,...) and arcs by adding symbolic(at_vector,...) to the list containing all geometrical objects comprising the graph. Why are these not displayed? Here's an example:
4. Xcas crashes on executing the following command:The command gives the expected results in my project.
_GT_CONNECTED = 142, // connected
_GT_SPRING = 143, // spring
_GT_TREE = 144, // tree
_GT_PLANAR = 145, // planar
_GT_DIRECTED = 146, // directed
_GT_WEIGHTED = 147, // weighted
_GT_WEIGHTS = 148 // weights
draw_graph(complete_graph(5))Code : Tout sélectionner
draw_graph(digraph(10,0.1))Re:
@jocaps: this algorithm seems like a good candidate for implementation, but I still have to read the paper carefully.
https://www.microsoft.com/en-us/researc ... re2013.pdf
Mendivelso J., Kim S., Elnikety S., He Y., Hwang S., Pinzón Y. (2013) Solving Graph Isomorphism Using Parameterized Matching. In: Kurland O., Lewenstein M., Porat E. (eds) String Processing and Information Retrieval. SPIRE 2013. Lecture Notes in Computer Science, vol 8214. Springer, Cham
Re:
Some answers and remarks:
1. The giacPCH.h include should be included first in the C++ files. I have also fixed the .h headers, begin with:
2. Adding new keywords for integers values should be done in lexer_tab_int.h
3. Edges are not displayed because segment/vector/... must be evaled. You can do that by calling _segment(makesequence(...),contextptr) instead of the inert symbolic form in graphe::append_segment
4. I get a Bad argument type error, not a crash.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
#include "first.h"
Re:
Sorry Bernard, I've indicated the wrong command. The problematic one isActually I also get the segfault, so it's possible related to my code, but I can't find the problem and don't understand the backtrace.
I have changed the lexer_tab_int.h file, adding the new options after lp_ ones. The file is attached below.
Adding edges to the drawing is now fixed and graphs should be displayed properly.
I've changed the order of the headers in my source as you specified. However, now my example program crashes before entering main. It probably has something to do with the header inclusion order. Here's the minimal main.cpp:The newest revision of my code contains your ordering of headers nevertheless. Can you check if it's correct?
draw_graph(random_digraph(10,0.1))I have changed the lexer_tab_int.h file, adding the new options after lp_ ones. The file is attached below.
#include "giacPCH.h"
#include "giac.h"
#include "graphtheory.h"
int main(){
  return 0;
}- Pièces jointes
- lexer_tab_int.zip
 - (4.92 Kio) Téléchargé 300 fois
Re:
The new ordering seems correct for inclusion in the library. Perhaps it does not work for some strange reason if you write a standalone executable...
For drawings, can you check that the points are also evaluated?
The segfault happens at line 5802 in graphe.cc,
because j=0 and n=0, hence n-1 is too large (if you put a breakpoint, this happens the 5th time).
double phi1=adj_phi[j==0?n-1:j-1],phi2=adj_phi[j%n];Re:
I've changed inclusion of vertices and labels, now _point ad _legende are called, not symbolic(at_point,...), symbolic(at_legende,...).
Thanks for locating the cause of the segfault, I think the problem happens because the graph has isolated vertices, so label placement algorithm gets confused (it tries to place the label to avoid the edges). I'll fix that.
Re:
By the way, here's the backtrace of the segfault occurring immediately after running my standalone program:Does it help to detect the problem?
/lib/x86_64-linux-gnu/libc.so.6(+0x70bfb)[0x7f08cac3ebfb]
/lib/x86_64-linux-gnu/libc.so.6(+0x76fc6)[0x7f08cac44fc6]
/lib/x86_64-linux-gnu/libc.so.6(+0x773b8)[0x7f08cac453b8]
/lib/x86_64-linux-gnu/libc.so.6(+0x78dfa)[0x7f08cac46dfa]
/lib/x86_64-linux-gnu/libc.so.6(__libc_calloc+0x27b)[0x7f08cac49b7b]
/lib/x86_64-linux-gnu/libc.so.6(+0x35b40)[0x7f08cac03b40]
/lib/x86_64-linux-gnu/libc.so.6(__cxa_atexit+0x19)[0x7f08cac03be9]
/usr/lib/libgiac.so.0(+0x25e7b5)[0x7f08cbceb7b5]
/lib64/ld-linux-x86-64.so.2(+0xf85a)[0x7f08cd87c85a]
/lib64/ld-linux-x86-64.so.2(+0xf96b)[0x7f08cd87c96b]/lib/x86_64-linux-gnu/libc.so.6(+0x70bfb)[0x7f08cac3ebfb]
/lib64/ld-linux-x86-64.so.2(+0xc5a)[0x7f08cd86dc5a]Re:
Bug fixed indeed!
I checked your simple test program, but it runs for me. The stacktrace does not help, all frames are in the system libraries...
Re:
Why giac can't be installed in debian 9 without apt-get making complaints about missing packages? After enabling the stable branch for giac in /etc/apt/sources.list and running apt-get update && apt-get install giac, I get:I got past this error by enabling wheezy backports, but I'm not sure that's the best way to do it.
Maybe this has something to do with my problems with standalone program?
Things worked at first, but apparently something changed in my system since then, I don't know what.
The following packages have unmet dependencies:
 giac : Depends: libjpeg8 (>= 8c) but it is not installable
        Depends: libpng12-0 (>= 1.2.13-4) but it is not installable
        Depends: libreadline6 (>= 6.0) but it is not installable
        Recommends: python3-giacpy but it is not going to be installed
        Recommends: python-giacpy but it is not going to be installed
        Recommends: libao-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.Maybe this has something to do with my problems with standalone program?
Re:
I've made a test program consisting only of the file giactest.cc:This program compiles fine withand runs at expected, but segfaults in the end, this is the backtrace:
This is with the latest Xcas binaries installed (rev. 63)
#include "giac/giacPCH.h"
#include "giac/giac.h"
#include <sstream>
using namespace std;
using namespace giac;
int main() {
gen g;
stringstream ss;
ss << "[1,2,3]";
ss >> g;
cout << g << endl;
return 0;
}Code : Tout sélectionner
g++ -g -Wall giactest.cc -lgiac -lgmpCode : Tout sélectionner
#0  0x0000555555554f88 in giac::gen::~gen (this=0x7fffffffe140,
    __in_chrg=<optimized out>) at /usr/include/giac/gen.h:692
#1  0x0000555555554e52 in main () at giactest.cc:9Re:
The stable and testing repositories are for older debian. For debian 9, you must install by hand (I mean with dpkg from the .deb on my web page).
For the standalone binary, does it work if you add -DHAVE_CONFIG_H?
