Latex output bugs?
Messages in english
XcasEngGuy
Latex output bugs?
Message par XcasEngGuy » sam. oct. 10, 2020 5:31 pm
I have been using the latex output for elegant printouts of work and when I started to use units in the calculations I think I noticed a few bugs.
Please find attached a diff printout of the tex file produced by Xcas with the modifications I needed to do to prevent errrors when creating a PDF. When I ran: latex <my original tex file> in cygwin I got the following errors:
! Missing { inserted.
<to be read again>
\left
l.96 \mathrm{Rl}=(_\left
(1,\mathrm{\_ft}\right)) \\
! Missing } inserted.
<inserted text>
l.96 ...hrm{Rl}=(_\left(1,\mathrm{\_ft}\right)) \\
Underfull \hbox (badness 10000) in paragraph at lines 99--101
[2]
<to be read again>
\left
l.102 \mathrm{Dl}=(_\left
(0.785398163397,\mathrm{\_ft}\right))
! You can't use `\eqno' in math mode.
\endequation ->\eqno
\hbox {\@eqnnum }$$\@ignoretrue
l.103 \end{equation}
<inserted text>
Underfull \hbox (badness 10000) in paragraph at lines 103--105
<to be read again>
\left
l.106 \mathrm{Al}=(_\left
(512.065886703,\frac{\mathrm{\_ft}^{2}\cdot \mathrm...
l.107 \end{equation}
<inserted text>
Underfull \hbox (badness 10000) in paragraph at lines 107--109
<to be read again>
\left
l.110 \mathrm{Al}=(_\left
(512.065886703,\frac{\mathrm{\_ft}}{\mathrm{\_s}^{2...
l.111 \end{equation}
<inserted text>
Underfull \hbox (badness 10000) in paragraph at lines 111--113
Underfull \hbox (badness 10000) in paragraph at lines 115--117
<to be read again>
\left
l.118 \mathrm{Fl}=(_\left
(512.065886703,\frac{\mathrm{\_ft}\cdot \mathrm{\_l...
l.119 \end{equation}
<inserted text>
Underfull \hbox (badness 10000) in paragraph at lines 119--121
<to be read again>
\left
l.122 \mathrm{Fl}=(_\left
(15.9119171679,\mathrm{\_lbf}\right))
l.123 \end{equation}
<inserted text>
I also attached the PDF produced by the "repaired" tex file.
The following is a bash script that I use as a work around right now to "fix" the tex file.
sed '
s/_\\left/\\left/g
s/,\\/\\/g
/(\\/{/))$/{s/(\\/\\/; s/))$/)/}}
/(\\/{/))[ \]*$/{s/(\\/\\/; s/))\([ \]*\)$/)\1/}}
' $1
Pièces jointes
attachments.zip
PDFs inside
(71.83 Kio) Téléchargé 1096 fois
Re: Latex output bugs?
Message par parisse » lun. oct. 12, 2020 6:25 am
Can you send the xws file? It will make easy to reproduce the bug.
XcasEngGuy
Message par XcasEngGuy » lun. oct. 12, 2020 8:06 pm
No problem.
Thanks
Pièces jointes
tex_latex_files.zip
I think this is everything
(11.58 Kio) Téléchargé 1086 fois
Message par parisse » mer. oct. 14, 2020 10:43 am
It's not that straightforward to fix, because under linux, the translation is handled by markup.cc, not by my code anymore.
I have fixed units printing in my code: now latex(_g_) will return "1\_\mathrm{\_g\_}". I hope this will be sufficient...
XcasEngGuy
Message par XcasEngGuy » mer. oct. 14, 2020 9:32 pm
Thanks. I think the most troublesome error is caused by the underscore after the = sign, before \left (see attached image)
Matt
Pièces jointes
Message par parisse » dim. oct. 18, 2020 5:35 pm
Yes, that should be fixed. And \_ will be infixed.
XcasEngGuy
Message par XcasEngGuy » dim. oct. 18, 2020 8:57 pm
I just updated to 1.6.0. Works great.
Thank you very much,
Matt
lukamar
Message par lukamar » ven. oct. 23, 2020 4:12 pm
Hello,
thank you Matt for reporting bugs, I made several fixes in markup.cc regarding typesetting of physical constants. I also improved deciding on whether multiplication should be explicit or not (now it is explicit also when multi-character symbols are involved).
I compiled the stable version 1.6.0 with the above fixes and everything works as expected. In particular, test.xws is typeset properly. I attached the output files below.
Note that latex export supports identifiers with subscripts: if you name a variable as e.g. "name_sub", everthing after underscore (_) will be typeset as subscript in latex output.
Pièces jointes
test.zip
(114.44 Kio) Téléchargé 1144 fois
XcasEngGuy
Message par XcasEngGuy » ven. oct. 23, 2020 9:41 pm
This appears to be exactly what I'm looking for. Is there a way for me to get a copy of this update?
Matt
lukamar
Message par lukamar » sam. oct. 24, 2020 1:26 am
It would be possible as soon as Bernard synchronizes the source. I'm maintaining markup.cc in a separate repository. You can get the new version from here: https://github.com/marohnicluka/giac and compile it yourself (replace the file in the latest stable source tarball).
Message par parisse » dim. oct. 25, 2020 7:59 am
The unstable bzip2 source file is synchronized.
https://www-fourier.univ-grenoble-alpes ... .0.tar.bz2
XcasEngGuy
Message par XcasEngGuy » lun. oct. 26, 2020 8:38 pm
I noticed the xcas64inst.exe was updated 24-Oct-2020. Does it include your code?
lukamar
Message par lukamar » mar. oct. 27, 2020 10:25 am
As it appears, it is compiled with the old version...
XcasEngGuy
Message par XcasEngGuy » ven. oct. 30, 2020 5:03 pm
I am trying to compile the unstable bzip2 source file under cygwin. I am getting missing include file errors. I downloaded the source tarballs for GMP, GNU readline, FLTK, MPFR, gsl, NTL (there is a windows version also, don't know which one to use), CoCoA, and PARI. Unfortunately, I don't know how to load them into cygwin so gcc can find everything.
I know you must be busy, but could you point me to a little more detail in how to successfully compile Xcas?
Matt
Message par parisse » sam. oct. 31, 2020 8:25 am
Most packages are already available in cygwin, so you don't need to compile them. Make sure you have installed the dev version (with headers). After that
make -f Makefile.win64
should do the job. Maybe you will have to edit Makefile.win64 and remove a library that you did not compile. The only mandatory library is GMP.
BTW, I have compiled a new version for windows.
