Latex possible bug?
Messages in english
XcasEngGuy
Latex possible bug?
Message par XcasEngGuy » sam. sept. 17, 2022 8:16 pm
It appears that xcas is no longer putting in the parenthesis around the argument in sin:
The xcas entry:
produces:
\(\left[\begin{array}{c}a=\mathrm{str2}\cdot \sin \mathrm{ang}\\b=\mathrm{str2}\cdot \cos \mathrm{ang}\end{array}\right]
% Generated by xcas
\documentclass{article}
\usepackage{pst-plot,color}
\usepackage{graphicx}
\begin{document}
\noindent \framebox{1} {\tt eq1:=[[a=(str2*sin(ang))],] } \\
\begin{equation} \label{eq:0}
\end{equation}
\noindent \framebox{2} {\tt } \\
\end{document}
Pièces jointes
XcasEngGuy
Re: Latex possible bug?
Message par XcasEngGuy » sam. sept. 17, 2022 8:23 pm
My post got corrupted somehow, hope you can understand it. I was not able to edit it.
Matt
Message par parisse » mar. sept. 20, 2022 3:00 pm
It seems it is a question for Luka.
Note that you can run
latex("legacy",1)
in your session before converting to latex, this should switch to my old latex code with parenthesis around the argument.
XcasEngGuy
Message par XcasEngGuy » mer. sept. 21, 2022 6:05 pm
Thanks. That helps but it breaks some of my recent tweaks using perl scripts to change diff(x(t),t,2), for example, to a more textboox style:
\(\frac{d2\left(\text{y(t)}\right)}{\mathrm{dt2}}=\frac{4 \sqrt{10} \frac{d2\left(x(t)\right)}{\mathrm{dt2}} \sqrt{x\left(t\right)}^{-1}}{2}-4 \sqrt{10} \frac{1}{2} \frac{d\left(\text{x(t)}\right)}{\mathrm{dt}} \frac{1}{2} \frac{d\left(\text{x(t)}\right)}{\mathrm{dt}} \sqrt{x\left(t\right)}^{-1} x\left(t\right)^{-1}
XcasEngGuy
Message par XcasEngGuy » mer. sept. 21, 2022 6:11 pm
Even better (added tweak):
\(\frac{d^{2}\left(\text{y(t)}\right)}{\mathrm{dt^{2}}}=4 \sqrt{10} \frac{d^{2}\left(x(t)\right)}{\mathrm{dt^{2}}} \frac{\sqrt{x\left(t\right)}^{-1}}{2}-4 \sqrt{10} \frac{1}{2} \frac{d^{}\left(\text{x(t)}\right)}{\mathrm{dt^{}}} \frac{1}{2} \frac{d^{}\left(\text{x(t)}\right)}{\mathrm{dt^{}}} \sqrt{x\left(t\right)}^{-1} x\left(t\right)^{-1}\)
lukamar
Message par lukamar » sam. sept. 24, 2022 1:35 am
New latex conversion omits parentheses when applying functions to simple arguments like e.g. x. I will add an additional condition that the argument must be a one-letter symbol, which should make the output better (one-letter symbols are typeset in italic, so removing parentheses wouldn't affect readability).
XcasEngGuy
Message par XcasEngGuy » dim. sept. 25, 2022 6:29 pm
Sounds good, Thanks
