Rearranging terms as with HP48GX
XcasEngGuy
Message par XcasEngGuy » mar. mars 02, 2010 8:06 pm
Hello,
Thank you for including me in this forum.
I have been using xcas for a while and was wondering if there is a way to rearrange terms as was possible in the HP48GX. Moving terms and collecting on subexpressions to achieve a desired form for a solution.
Any suggestions?
Thank you in advance
Matt
Re: Rearranging terms as with HP48GX
Message par parisse » mar. mars 02, 2010 9:01 pm
Yes, you can rearrange terms interactively inside an expression editor. For more information, please look at the Expression editor section in the interface help manual (Help->Interface in xcas or open file:///usr/share/giac/doc/en/casinter/node6.html under linux/ add local after usr for mac, c:\xcas\doc\en\casinter\node6.html under windows)
XcasEngGuy
Message par XcasEngGuy » mer. avr. 07, 2010 11:19 pm
I looked at the expression editor. I am not sure how to put an existing expression or equation into the editor. Also, I was looking for the ability to rearrange terms, distribute into a parenthesis, swap terms etc. In the HP48 you have a lot of freedom to merge terms, move terms, swap, etc. It appears that using normal or factor on a selected subexpression is most of it. I appears more adapted to entering equations.
I hope this makes sense.
Matt
Message par parisse » jeu. avr. 08, 2010 7:09 am
You can paste an existing equation with Ctrl-C/Ctrl-V. Then up-arrow to select it, and you can re-arrange it. You can apply any command (taking one argument) from the main menu, it is not limited to those from the M menu of the expression editor. If you want to swap terms, select one, use Ctrl-left or right arrow.
XcasEngGuy
Message par XcasEngGuy » sam. avr. 10, 2010 6:08 pm
parisse a écrit :You can paste an existing equation with Ctrl-C/Ctrl-V. Then up-arrow to select it, and you can re-arrange it. You can apply any command (taking one argument) from the main menu, it is not limited to those from the M menu of the expression editor. If you want to swap terms, select one, use Ctrl-left or right arrow.
When I paste in an equation using Ctrl-C it appears to be entered as a string (it has a double quote at the beginning) and any operation yields an error message "bad argument".
Message par parisse » sam. avr. 10, 2010 6:59 pm
If you are in string mode, press the " key, it will come back to normal mode.
XcasEngGuy
Message par XcasEngGuy » mar. avr. 13, 2010 4:17 pm
Is there a way to change an normal entry line to an expression editor line (without creating a new expression editor line and pasting in?)
I hope that was clear
Message par parisse » mar. avr. 13, 2010 4:41 pm
No, not currently. The shortest path is Ctrl-A, Ctrl-C, Alt-E, Ctrl-V, downarrow, "
XcasEngGuy
Message par XcasEngGuy » jeu. oct. 21, 2010 5:46 am
I understand the expression editor now. The editor in the HP48 could distribute a multiplier into a quantity, invert, move parentheses etc. I had wished for that. It would need to operate on equations that were the result of other operations like solve or subst.
I find I am using XCAS more and more. The combination of XCAS and Octave makes a powerful tool for modeling and other engineering tasks.
Thank you.
